February 02, 2026, 03:14:11 AM
Big Bike Things HIghway/curiser pegs
Topic: Big Bike Things HIghway/curiser pegs (Read 1589 times)
Pale Rider
April 01, 2011, 11:07:28 AM »
I received a pair of Big Bike Things cruiser pegs as a gift. These are the ones that clamp to lower portion of the crash bars and are about 8"-10" in length when fully folded out. The right side mounted well, but the left side mounted poorly and are not symmetrical to the right side. They sit significantly lower and I think could present issues when leaning into a corner. Does anyone else have experience with these? I know the crash bar is angled inward on the left side. I can't get my mind around this one.
Re: Big Bike Things HIghway/curiser pegs
April 01, 2011, 01:42:03 PM »
If you look real close, the left guard is not in the same area as the right. This is because the pistons do not match exactly straight across from each other. There is an offset.
So to get theem to be of the same height and length, you have to be a little magical and eyeball them to line them up.
Now, I'm ssuming this is what you are talking about. If it isn't, then I'm in the dark also as mine match each other for height and forward measurements with a little finiggling around.
