February 02, 2026, 03:13:09 AM *
Author Topic: dan marc fuel valve  (Read 1760 times)
N0tac0p
« on: April 04, 2011, 06:58:27 AM »
i saw a discussion on hydrolock where a link sent me to Dan marc.  they have is there a particular valve (which i may simply find) but more importantly what is the hose size that i mate to?
Kaiser
Gainesville, FL
« Reply #1 on: April 04, 2011, 07:10:31 AM »
There were two different models that were discussed previously that will work.  It seems like the consensus (and the one I bought - therefore the best  cooldude) is the AFC-152.
Word to the wise: when you wire it up to your bike...do NOT use the supplied Scotch-Lock connectors.  My bike wouldn't start after I hooked up my Dan Marc, and I traced it back to the Scotch-Lock not even breaking through the insulation on one of the tapped wires.  (Of course, if you have any electrical experience, you already knew not to use those crappy connectors.)
I forget the measurement of the fuel line.  Sorry.
Bullgoose
Bastrop, Tx
« Reply #2 on: April 04, 2011, 07:21:21 AM »
5/16 I believe. Just replaced mine.
If it's worth doing, it's worth over-doing!
