February 02, 2026, 03:14:41 AM
Fuel Leak
Topic: Fuel Leak (Read 1481 times)
Poor Ol Harry
Baytown,TX. East of Houston
Fuel Leak
April 04, 2011, 08:25:48 AM »
While stoping for a cold drink ,I had a seat beside my 1999 IS, 60K miles.....I was sitting eye level with bottom of the tank on the curb side....... just below where the seat & tank meet there is a window of daylight about as big as your hand with a few hoses in sight..........I noticed a small hose or cable 1/4 inch or + running front to rear & not up & down was dripping tiny drips of gas as if it was coming from up above & dripping at that point.........I have heard horrow stories about petcock problems.I have never moved the valve off/res in the 2+ yrs. I have had it.Is this drip a warning or any pointers on what to look for.The bike is parked with fuel valve turned to off HARRY
Re: Fuel Leak
April 04, 2011, 08:36:34 AM »
Yep, a good indication that there is a problem with the petcock.
And you must see that turning it off stopped the gas dripping?
Mildew
Live, Not Just Exist
Auburn, Ga
Re: Fuel Leak
April 04, 2011, 11:54:49 AM »
Those 2 petcock diaphrams inside are just nickle size and very, very thin like a balloon. When I took mine apart out of my 98 model recently, I just stretched them a little and saw daylight as it was tearing from dryrotting. I'd say it's time to fix it. Since your not in the habbit to turn yours off, I would buy the rebuild kit for 20-35 bucks. That way the vacuum part will more than likely save you but it's better to get in the habbit to turn it off imho
