February 02, 2026, 03:14:06 AM *
Author Topic: Fuzeblock - has any body used this one?  (Read 2026 times)
lljjmm
« on: April 04, 2011, 08:39:49 AM »
Has anyone have experience with this particular fuse block? It has options others don't have and still being compact. Has 6 outlets with options of switching  on with key or just on. It is a little pricey, but if you figure cost of adding a relay and a fuse block it is not much different. Any comments
www.fuzeblocks.com
« Last Edit: April 04, 2011, 05:09:00 PM by lljjmm » Logged
bikerboy1951
Grand Forks, ND
« Reply #1 on: April 04, 2011, 10:00:57 AM »
I had one I bought and used on an ST1300.  It worked as advertised.  No problems at all.  Compact size made it nice for mounting.  I would highly recommend it.
Brad
Redline +
Northwest Washington
« Reply #2 on: April 04, 2011, 03:53:51 PM »
www.fuzeblock.com
I just installed one on my Valk, very compact and easy install with the relay built in. Calculate your loads and make sure you don't overload the Fuzeblock. IIRC, 10 amp max per circuit, 30 amp max total.
Your link didn't work for me, I think this will.
http://www.fuzeblocks.com/
Redline  Cool
« Last Edit: April 04, 2011, 04:05:00 PM by Redline :) » Logged
