November 22, 2025, 06:01:58 PM *
Author Topic: Painting the plastics  (Read 1487 times)
PhredValk
Edmonton, Alberta, Canada
« on: April 04, 2011, 10:09:14 AM »
Hi, gang. I took my saddlebags off to get painted (99 I/S, green/silver). Having a discussion with the roomie, I brought the worst of the two up from the basement to show him what I needed, and he said 'Get some sandpaper and do it yourself'. It's just scratches, no real gouges or holes, and I can get matched paint from ColorRite and clearcoat from a local paint store, so:
What kind and grit number sandpaper would you use? Sand by hand or get an electric palm sander?
Is there some kind of product I should use to fill the scratches before sanding (like for CD/DVD discs)?
Is there anything I should use for sealer? Primer? I'll be using the aerosol spray can paint.
Remove all hardware or just mask/paper? I won't be painting near the hinges or locks, but will have to remove the I/S logo and reflector (thinking of replacing the reflectors with LEDs anyway).
I haven't seen any paint threads, but I'm sure some members have done touch-up paint on bikes/cars/boats etc.
Thanks, Fred.
« Last Edit: April 04, 2011, 10:13:04 AM by PhredValk » Logged
VRCCDS0237
tybme
1999 Valkyrie I/S
Topeka KS
« Reply #1 on: April 04, 2011, 01:52:09 PM »
Speaking from personal experience. Hire a professional - getting the paint to lay down correctly is very hard to do if you aren't experienced.
I painted a gl1100 a couple years ago - after I was done the faded, scratched paint looked much better than the work (at least 40-60 hours) I put into it.
If you know what you are doing - go for it but I'm guessing from your questions you lack the experience - as I did.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways. totally worn out, shouting, "Holy ****... What a Ride!"
BradValk48237
Oak Park, MI
« Reply #2 on: April 04, 2011, 06:38:28 PM »
There is also clear coat on them if I am not mistaken.....
I agree on having a professional do it.... will save time for you and get you a much better end result.... blending old and new paint takes some skill... which I DON't have....
Hey...... It's only money after all.
B
arm
RATHBUN IA
« Reply #3 on: April 11, 2011, 08:42:50 AM »
 Smiley JUST HAD MY TWO SIDE BAGS AND THE TRUNK REPAINTED AT A LOCAL BODY SHOP. $500.00 BUT THEY LOOK LIKE NEW AND A PERFECT MATCH..
ARM
« Last Edit: April 11, 2011, 08:45:27 AM by arm » Logged
