February 02, 2026, 04:47:48 AM *
Author Topic: New OEM Oil Filter  (Read 2221 times)
Wegs
« on: April 06, 2011, 03:40:14 PM »
Just ordered a case of the new OEM oil filters  (15410-MFJ-D01)and found out the Rivco chrome oil filter cover will not fit it. Took the chrome cover to my Buddies and had him turn it down so it will fit. I know alot of Valk owners that have the Chrome cover might be a little upset when they get the new OEM filter. Just giving everyone a heads up. The filter cover is thick enough that you can have it turned to fit though.
F6Dave
« Reply #1 on: April 06, 2011, 06:43:02 PM »
My Rivco cover fits on the WalMart Super Tech filters, though the filter is a bit longer so some of it is exposed at the bottom.
Hawkeye
Horry County, South Carolina
« Reply #2 on: April 07, 2011, 05:42:33 AM »
I use the Honda Element oil filter and oil drain plug crush washer.  Tried the Wal-Mart filter (the larger one) and it leaked slightly; there appears to be a small difference in the size of the Wal-Mart gasket which could have accounted for the leak.  I like the look of the Honda blue filter up front.
Spirited-6
Nicholasville, Ky.
« Reply #3 on: April 07, 2011, 06:24:26 AM »
I have used Super Tech Filters for about nine years and never had a leak on a 1100 Spirit or a 98 Tourer. I sometimes paint sliver or cut a 7/up can to fit.  cooldude
Spirited-6
2qmedic
Simply Awesome!!!
« Reply #4 on: April 07, 2011, 08:08:33 AM »
I have used the super tech filter #3593A of which is a larger capacity filte. Never had any problem.
I also paint mine silver. OK...it's not chrome but I do have a larger capicity filter!!! cooldude
I currently us the Purolator PL14459.
It has a larger capacity than OEM,
Filters out smaller particles,
Filtering surface area is many times OEM.
http://www.calsci.com/motorcycleinfo/Filters.html#OilFilters
« Last Edit: April 07, 2011, 08:17:37 AM by 2qmedic » Logged
Farther
Quimper Peninsula, WA
« Reply #5 on: April 07, 2011, 04:13:57 PM »
+1, it is also the same filter for my Honda Fit.  I buy them by the 1/2 dozen from H&A Honda.
~Farther
