February 02, 2026, 04:47:46 AM
Front suspension question...
Topic: Front suspension question... (Read 1727 times)
Bugslayer
Lubbock, Texas
April 08, 2011, 03:27:50 AM »
Question about the front forks:
If I understand right, one leg controls compression, the other is rebound. Which leg does what?
Joe Hummer
Arnold, MO
Re: Front suspension question...
April 08, 2011, 05:28:26 AM »
Right leg is dampening...I am not sure how to say the other leg works. It doesn't have a dampener in it. Just another, smaller, spring.
Front Forks Blowout
Check the microfiche. You can see the difference parts.
Joe
1999 Valkyrie Interstate
A little knowledge in the wrong hands .............
April 08, 2011, 08:06:04 AM »
Both front shock absorbers do what the description says. Absorb shocks and do it in the same way.
The only difference between them is that the right shock absorber has a damper in it for rebound attenuation.
That's enough of a difference to make servicing them different... But all of the parts that you would normally change are the same for both sides.
Bugslayer
Lubbock, Texas
April 08, 2011, 08:25:04 PM »
Thanks for the help.
