Beware of purchasing from KENNEDY TECH GROUP (Cables & etc.)
Started by BigM, Fri 08, Apr 2011, 12:25:27
Previous topic - Next topic
BigM
POOR CUSTOMER SERVICE ! ! They sell cables for gps and etc. for m/c's.
BEWARE of purchasing from this company. Say they will return but won't. Hooking up gps on my Valk. Bought the right cable (80.00) but they didn't tell me I would need additional cables for it to work. They then wouldn't take the purchased cable back saying is was the right one leaving me with it or purchasing more cables. And more expense. Which would leave me paying more for cables than the Da**  GPS .  They have their own scheme going.   POOR CUSTOMER SERVICE!
Bobbo
Is this the setup you bought?
http://www.cellset.com/65352R0-I.pdf
If so, it shows several optional cables and devices.  Maybe you didn't ask enough questions before purchasing.
(No affiliation, etc...)
BigM
She said that the one cable is all I need and could return if didn't work. The point is when I called and told them that my bike didn't have any of that cable connections, then they say I would have to have more cables. (First being 80. then another 34. and another at 34. plus shipping)Well I do the math and the cables needed would be more than the GPS itself. So I decide not to go with a GPS. I call to return the one cable. Then they won't refund because it was the right cable. After telling me they would (being didn't work, me thinking same as couldn't use). JUST a scam to buy all the high dollar cables. Figure  their business is on the brink and they don't really care if get any more business or not. Getting every dollar scam or not before they go under.Thats why I posted to warn fellow Valksters of being stuck with this Co.
PharmBoy
I am totally satisfied with their product and service.  My I/S sounds like it has a Bose system when played with the MP3 system in the Zumo.  If you byt what they recommend, You will have good tunes.  Stude 31 will back me up on this one....JTL
4th Infantry Tet Vet
99 Interstate
97 Bumble Bee
97 Red & White
MP
Quote from: PharmBoy on Fri 08, Apr 2011, 17:28:50
Put my Zumo 550 on with their cables.  Works great, totally satisfied.
MP
"Ridin' with Cycho"
I have both Deerslayer and my wing set up with the Amplirider, pre-amp and mixer.  No extra cables required - everything plugs in with mini-stereo plugs.  Mixes 3 devices.  $65 including shipping when I bought mine a couple years ago.  They are at http://www.electric-avenues.com/amplirider.html
BTW I usually use my Zumo 550 for tunes nowadays, though both bikes will use any player that has mini-stereo plug outputs - so also use Ipod, Riovolt portable disc player, and Archos MP3 player (now retired).
From my audio install page at http://www.horseapple.com/Valkyrie/Tech_Tips/Jammin_with_Blaupunkt/jammin_with_blaupunkt.html  -
Searching for various pre-amps that would fit my need, I found I think the perfect pre-amp for this application - and many others in fact, so I bought another for my wing.  The AmpliRider, found for $65 incl shipping 7/09, at http://www.electric-avenues.com/amplirider.html This unit serves the same function as the Kennedy Cell Set which I had already bought for my wing, and never bothered to install yet.  For MUCH more $$$$. Kennedy wants you to buy seperate adapters for every connection at prices I just won't pay - I was going to hard wire everything, but now, I can just plug in all the mini-stereo plugs!  It's a small amplifier, with all mini-stereo connectors except the power and ground which you hard-wire.  It has 3 inputs that it will mix and output to the single output (you can use for say radar, GPS audio, and music), and a remote volume control you can put anywhere.  Very well made, solid, looks like ABS plastic enclosures - compact and available with different wire lengths.  I asked Gary for some extra short volume wires on the 2nd one I bought - now I'll use the longer wires for the wing and sell the never-installed Kennedy.  The Wing install, had previously required a ground loop isolator to eliminate a buzz for the input from first a RioVolt SP250 player, followed by an Archos Recorder, and now the Ipod Classic.  The input for the radar - and I suspect the GPS (though I didn't connect it - don't need a woman's voice nagging me where to turn), required an isolator transformer - radio Shack P/N 273-1374, $3.99, and a couple mono solder plugs and audio wire.  (Gary just said, he will mention on the AmpliRider's website that isolation cables may be needed for some detectors, and that they are available prewired.) I also needed a mono wire with male mini plugs both ends, and a mono-stereo female-male (respectively) adapter plug to adapt the mono signal from the radar to stereo to import into the AmpliRider.  Used here, the tunes have more than double the volume from before, and the sound is cleaner, and I have a volume knob instead of that useless slide-your-finger volume control on the Ipod.  The radar signal is plenty loud, cannot be missed.
CISE
I have the KTG Cell Phone/Bluetooth unit for my 99 I/S - went back and forth with them a few times becuase of my errors. But they gave me what I needed & took back what I had erroneously ordered.
Only issue I have is the replace the bluetooth receiver - they want 80.00 for it and I found it elsewhere at 2 for 25.00.
Maybe I just got lucky and the CSR did not mind a goofy old fart calling and flirting repeatedly.
tybme
Sorry to hear you had a bad experience with them. I have purchased from them several times and have had nothing but good things to say about them.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways. totally worn out, shouting, "Holy ****... What a Ride!"
alph
Quote from: Bobbo on Fri 08, Apr 2011, 12:33:25
holy cripes!!  didn't know they had sooooooo many options!!  wish i knew that they could do all those set ups, i probably would have went there and got hook ups instead of dealing with 'em on my own!!  thanks for the web site info bobbo.
Ride Safe, Ride Often!!  :cooldude:
