February 02, 2026, 04:47:38 AM *
Author Topic: Looking like a fiddler crab.  (Read 2335 times)
bigguy
VRCC# 30728
Texarkana, TX
« on: April 08, 2011, 01:57:34 PM »
My clutch lever is hard to pull and hold. The workout I'm getting with my left hand will have me looking like a fiddler crab before much longer.
It there an easy way to reduce the pressure needed to disengage the clutch?
Here there be Dragons.
« Reply #1 on: April 08, 2011, 02:08:11 PM »
Okay, for a starter, tell us what changes or mods you have done to the clutch area in the last few weeks/days and etc.
It can usually be defined as the latest mod you did.
bigguy
VRCC# 30728
Texarkana, TX
« Reply #2 on: April 08, 2011, 02:15:23 PM »
It's been this way since I got it. It just took me a while to complain about it. It looks stock to me. I don't think there are any mods.
John U.
Southern Delaware
« Reply #3 on: April 08, 2011, 03:02:34 PM »
Have you bled the clutch fluid lately/ It might help a bit.
You can also get adjustable Goldwing levers. Showchrome makes a set, so does Kuyakyn. They are longer than Valk levers and will give you some additional leverage.
There is a recent thread on this subject.
« Reply #4 on: April 08, 2011, 03:51:07 PM »
Get one of these things and only use it with your right hand until you look symmetrical again.
MP
North Dakota
« Reply #5 on: April 08, 2011, 03:56:34 PM »
The GW chrome adj. levers on mine make it MUCH easier to pull.
MP
"Ridin' with Cycho"
« Reply #6 on: April 08, 2011, 04:14:29 PM »
There's a whole bunch of stuff going on at the lever pivot point... spray some wd40 (or something better,
like tri-flow) up in there around where 1 and 7 and 20 and 12 are... the clutch should be easy to pull...
NW roller
Dunkirk MD
« Reply #7 on: April 08, 2011, 04:56:16 PM »
Mine pulls easy and its stock.
Those who won't listen must feel.   David B
Lucky Duck
Inverness, FL
« Reply #8 on: April 08, 2011, 05:28:02 PM »
I would try to clean it up. Remove the jam nut #18 and using a flat screwdriver, remove the bolt that holds the lever in place #16. You'll see that the bolt goes thru a bushing. Clean the bushing, check for wear and if it's not worn, lightly grease it and put it all back together. That can't hurt to do, even if it turns out to not be the problem.
OverdueBill
Elkmont, Alabama
« Reply #9 on: April 08, 2011, 05:34:45 PM »
I just changed my clutch fluid and it seemed easier to operate.  I didn't see how it would make a difference but I'm all for easier.  It was past looking like tea and more like coffee.  Overdue is my name.
Blackduck
West Australia
« Reply #10 on: April 08, 2011, 05:39:55 PM »
+1 on doing the easy first. Inspect the pivot pin, bush and relube.
Look at replacing the clutch fluid, particularly if you don't have a good service history on it.
How many miles has it done?
Cheers Steve
bigguy
VRCC# 30728
Texarkana, TX
« Reply #11 on: April 08, 2011, 06:58:07 PM »
This may be the real solution. I just got back from BikeNight where there were three other Valks. My clutch was the easiest pull of the bunch.
Russell Rice
I think I can, I think I can, I think I can!
Owasso, Oklahoma
« Reply #12 on: April 08, 2011, 07:16:37 PM »
Mt. Vernon, IN
Re: Looking like a fiddler crab.
« Reply #8 on: Today at 05:28:02 PM »
I would try to clean it up. Remove the jam nut #18 and using a flat screwdriver, remove the bolt that holds the lever in place #16. You'll see that the bolt goes thru a bushing. Clean the bushing, check for wear and if it's not worn, lightly grease it and put it all back together. That can't hurt to do, even if it turns out to not be the problem. cooldude cooldude cooldude cooldude
« Reply #13 on: April 09, 2011, 08:43:28 AM »
Gryphon Rider:
Although the reply is a little harsh (laughter), I have to fully agree with your analysis of the problem.
« Reply #14 on: April 09, 2011, 04:39:41 PM »
Gryphon Rider:
Yep, sometimes the answers become obvious with a little distance and perspective.  Like when someone asks the most cost-effective way to make his Valkyrie more powerful so he can beat his buddy who has a slight edge on him.  The answer: lose weight!  If I and my 100 HP bike weigh 1000 lbs, 10 lbs lost = approx. 1 HP gained
Hoghead
Kilgore, TX
« Reply #15 on: April 09, 2011, 06:04:50 PM »
Hey Bigguy were gonna have a ET wrench party in June. Date tbd. Come on up and we'll fix it up. laugh Matt
2000 I/S. Coronado Blue & Silver
1984 V65 Magna. Really Fast Black
E. Texas Patriot Guard Rider
bigguy
VRCC# 30728
Texarkana, TX
« Reply #16 on: April 09, 2011, 08:44:54 PM »
I see you're just as couple of hours south of me. Is the wrench party in Kilgore? When in June?
