November 22, 2025, 06:01:57 PM *
Author Topic: cb radio antenna placement?  (Read 1240 times)
boss hoss bill
« on: April 09, 2011, 01:23:38 PM »
I picked up a used J and M CB that's going on my 2003 standard.
I was looking at the bike and wondered if i mounted the antenna  base, at the same height as my license plate if it will work OK?
The antenna is a Firestick about  3 feet long
Bill
« Last Edit: April 09, 2011, 04:28:24 PM by boss hoss bill » Logged
« Reply #1 on: April 09, 2011, 01:57:15 PM »
If memory(lol)serves-you want a good ground and the tip of c b antennae straight up. back of bike o-k with the good ground. The only person it has to look good for is you. 2funny When you get it all hooked up don't forget the S W R meter check. Hope this helps. coolsmiley RIDE SAFE.
« Reply #2 on: April 10, 2011, 08:51:14 AM »
Make sure you have a good GROUND on it.
My original one on my Yamaha Venture, older style, I mounted it under the bike in the swing arm area.    Worked good till I ran over a road alligator.   That chunk of rubber raised 4377 with a lot of the wiring under there.
After that I made a mount off of the tour box for it.
I was trying to look cool and make people think I didn't have a CB on it.
scoot
Lifes too short Ride it hard
Grand Rapids Mi.
« Reply #3 on: April 10, 2011, 05:08:24 PM »
 I have the J&M radio on my Valk. I mounted the antenna on the plate as you mentioned. I did shorten the brkt. so it mounts as close to the plate edge as I could get it.
 I think J&M suggests it be at least 18" from the closest passenger. Mine is close to that. I did run the ground to the fender strut ( ground is everything ).
