November 22, 2025, 07:33:33 PM *
Author Topic: rear signals  (Read 1496 times)
N0tac0p
« on: April 11, 2011, 10:22:04 AM »
is there an easy way to just change out the bulb socket to 1157 / 3157 ?  and use  a dual color light for signals and brakes?
olddog1946
Moses Lake, Wa
« Reply #1 on: April 11, 2011, 10:59:56 AM »
shouldn't be that big a deal, if you have your own lights/sockets...there are three wires to the 1157, ground, light, and turn,,,,just makes sure you've got a ground on both sockets/bulbs you put in place
On second thought, there may not be three wires physically,,,but the leads to the 1157's are the hot ones and the base/case is the ground...
« Last Edit: April 11, 2011, 11:02:13 AM by olddog1946 » Logged
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
Bobbo
Saint Charles, MO
« Reply #2 on: April 11, 2011, 11:02:43 AM »
What is a dual color light?  Do you mean an LED bulb replacement?  If so, you could use the stock amber lens for both red running lights and amber turn signals.
« Last Edit: April 11, 2011, 11:04:37 AM by Bobbo » Logged
tank_post142
south florida
« Reply #3 on: April 11, 2011, 11:21:10 AM »
my last valk i got the wire harnesses from the frt signals installed them in the back and wired them for turn+run. used pre 86 sportster red lens ( had to shave a couple thousands around the edge then they popped right in)
I got a rock Sad
VRCCDS0246
Mr.BubblesVRCCDS0008
« Reply #4 on: April 12, 2011, 08:04:13 PM »
you can get replacement sockets from autozone that are dual contacts and JB weld them into the rear housings. You'll have to pull power for the running lights from the lics. plate light. Make sure you get a good ground on the socket.Sylvania 3496 bulbs have a brighter element  for the blinker the a stock 1157.
X Ring
VRCC #27389, VRCCDS #204
« Reply #5 on: April 13, 2011, 08:23:02 AM »
This is the only way I can think of where you'll get 2 different colors for brake and turn signals out of the same turn signal pod.  http://www.valkyrieriders.com/shoptalk/ledturnsignalmod.htm
Marty
« Reply #6 on: April 13, 2011, 08:34:52 AM »
You can get a set of front turn signals (1157s) from Pinwall for cheap and mount them in the rear.
Or you can get a controller to convert 1156 rear signals to run-turn-brake (I have this on my supervalk).
In either case, you need red lenses to replace the ambers since you may not run full-time ambers in the rear.
