November 22, 2025, 09:03:38 PM
Timing belt tensioner
Topic: Timing belt tensioner (Read 1722 times)
thfrider
April 11, 2011, 06:36:35 PM »
Changed my timing belts this weekend, had no problems at all. I am puzzled by one thing. What is the purpose of the springs on the tensioners if you tighten the bolts down? When I first saw them I thought the springs maintained the tension on the belts.
Bad On 3
RIDIN THE BEAST ! !
CHICAGO IL. 60638
Re: Timing belt tensioner
April 11, 2011, 06:59:57 PM »
Hi as i understand it if you didnt have the springs you would have no play and the belt would break easly --you need some kind of give like on a car with the spring loaded tensioners on the pully -- if you dont have any give the belt would snap --the springs take up the slap so the belt wont break --also the springs keep the belt tight when it wears in --
Ridin Down The Road Of Life With My Friends !! What a Ride !!
Joe Hummer
Arnold, MO
April 12, 2011, 05:02:40 AM »
The springs put a preload on the tensioner until you tighten it...kind of a starting point.
1999 Valkyrie Interstate
thfrider
April 12, 2011, 06:38:21 AM »
Thanks for the reply. It makes sense that it just gives you a starting point because once you lock those bolts down, that spring is not doing anything. I let the spring set the tension and then I added just a little. If you push on the belt you get about .3" deflection. I ran the bike with the cover off and everthing looked and sounded fine.
April 12, 2011, 07:21:48 AM »
Well you'll know over time if everything is correct.
Those tensioner bearings will start to squeel if they're too tight.
No to mention abnormal wear on the belts.
=> InZane XXV
