November 22, 2025, 07:33:14 PM *
Author Topic: headlamp and rear running lights out  (Read 1281 times)
Woodman
« on: April 12, 2011, 06:56:31 PM »
Both headlight and rear running lights out.  High beam and turn signals working front and rear.  Fuses OK.  Can this be a simple matter of headlight replacement?
X Ring
VRCC #27389, VRCCDS #204
« Reply #1 on: April 12, 2011, 07:05:47 PM »
Rear running lights?  Unless you've got an I/S or you've modified your Standard/Tourer's rear turn signals, you don't have  rear running lights except for your tail light.  You probably need a new headlight bulb if your low beam is out.
Marty
Woodman
« Reply #2 on: April 12, 2011, 07:08:28 PM »
Thanks Marty!  Don't look much behind me and thought that the rear turn signals also were running lights.  Will replace the bub and see how it goes!
tank_post142
south florida
« Reply #3 on: April 12, 2011, 09:32:55 PM »
remember there are NO amber lights facing rear on any car or bike, except for turn signals
I got a rock Sad
VRCCDS0246
X Ring
« Reply #4 on: April 13, 2011, 08:27:54 AM »
At least weekly, MSF says before every ride, you should inspect you bike for obvious things not working.  Iirc the acronym is TCLOCS.  Tires, Controls, Lights, Oil, Chassis, Stand.  For more info go to www.msf-usa.org
HTH,
Marty
