February 02, 2026, 06:29:21 AM
brake pads--front
Topic: brake pads--front (Read 2022 times)
slider
mulberry arkansas
brake pads--front
April 13, 2011, 01:58:48 PM »
any of you professional valk guys recomend front brake pads--OEMS are what im thinking ..how about the creamic pads??thanks again..Im still learning proper care and feeding of my dragon,but with all the great help and advice i have got in the past I know The ones recommended will be the best ones for my BB
a proud navy veteran
BIG COUNTRY 23321
Me & My Death Horse
Chesapeake, Virginia
Re: brake pads--front
April 13, 2011, 02:11:52 PM »
Just replaced all mine with OEM. If you start mixing the EBC's and other Brake Pads with OEM Rotors then you will get nothing but heartache. Now if you are going to change your rotors to EBC then go with EBC Pads. I dont think this is a "War" Subject like Oil and Tires but you never know.
GOOSE
D.S. #: 1643
Southwest Virginia
April 13, 2011, 02:49:30 PM »
slider...bigcountry is right-on about the pads...the genuine TOJO-HONDA brake pads are the best way to go.
John U.
Southern Delaware
April 13, 2011, 04:57:59 PM »
The OEM pads will go easy on your rotors, which are way expensive compared to pads. If you want to use alternate brand pads, use their rotors as well.
April 13, 2011, 07:07:10 PM »
I've never used anything but OEM pads, but I like them...
PhredValk
Edmonton, Alberta, Canada
April 13, 2011, 11:47:24 PM »
I went with the cheapo pads on the rear when she started complining vocally that she needed them. I haven't had decent rear brakes since (about 4 weeks before winter storage). I thought maybe needs bleeding. Going Dark before I take her out this spring, so rear brakes will be important.
Got my MityVac in the mail today, and will bleed the crap out of the rear to see if it helps. If not, OEM all around in May.
Fred.
VRCCDS0237
Reply #6 on:
April 14, 2011, 06:10:14 AM »
Oem pads on bike when i got her. Prior to replacing with oem pads-and the wear grooves gettin close had an occasion that in volved a really hard stop. I'm still here-so is the bike-and btw-so are all 3 of my rotors. Look on HDL parts fiche-pads way way cheaper than rotors.
RIDE SAFE.
Earl in Pensacola
Reply #7 on:
April 14, 2011, 05:32:15 PM »
I have a '97 Tourer and when it came time (2001) to replace my first rotor (the rear) I found that the EBC cost about 1/2 as much as the OEM, so that's what I went with along with new OEM pads. No problems or noises. Likewise, when it came time to replace both front rotors, again EBC's with OEM pads!! Still no problem or extra noises. At 234K I'm still on the EBC front rotors, which have gone thru about 3 set of pads, so far. By-the-way, as far as "break-in" goes, all I do is ride normally, no gentler or harder stops than necessary, just as needed.
