February 02, 2026, 06:28:42 AM *
Author Topic: shifting to second  (Read 3846 times)
Tibado
« on: April 13, 2011, 02:34:30 PM »
After 35 years in the saddle, I finally own a Valk, two actually.
A 99 and a 2000 Tourer. The 99 grinds going into second gear about 80 percent of the time. I have to
go to neutral, release the pressure then it goes into second normally.
Clutch or shifter dog ? Bought this one from a Honda dealer who says it shifts just fine .
Any suggestions would be appreciated. I ride the 99 and my SO rides the 2000.
« Reply #1 on: April 13, 2011, 02:40:12 PM »
try bleeding the clutch line and also check the brass bushing in the handle(you are looking for worn wallered out holes).  Quick easy fixes before you go deeper
SANDMAN5
Mileage 65875
East TN
« Reply #2 on: April 13, 2011, 04:00:36 PM »
Ditto on bleeding the clutch line!! Changed my fluid this
winter and it made a MAJOR difference!! cooldude
Earl in Pensacola
« Reply #3 on: April 13, 2011, 05:50:40 PM »
Have you tried a little "pre-load" on the shifter?  Try just a  little lift on the shifter before you're ready to pull in the clutch lever.
BlueValk
Albuquerque, NM
« Reply #4 on: April 13, 2011, 05:56:03 PM »
Sounds like your dealer is passing his headache on to you.
Yes, there are better and worse ways to shift.  But, you've been riding for 35 years, you know how to shift.
My Valk shifts just fine without any extra attention.   Yes, preloading does make for a smoother shift, but that isn't the question here.  Try and get your Dealer to step up.  My .02.
BlueValk
« Last Edit: April 13, 2011, 05:59:18 PM by BlueValk » Logged
BigMac (SoCal)
Moreno Valley, California
« Reply #5 on: April 13, 2011, 09:39:37 PM »
Some just shift easier than others. I have had 2 valks and both of them shifted clunky. I have to peload them to shift easier. 92,000 on my 99 Interstate and all is good, you just get used to it. I work on a lot of Valks and some shift so nice compared to mine.
Dave
mario
NW Houston, TX
« Reply #6 on: April 13, 2011, 09:46:52 PM »
okay, ya'll. please explain 'preload' for me.  my valk's been hard downshifting lately.
Mario
01 Valkyrie Standard (sold)
12 Suzuki V-Strom 1000
Mr.BubblesVRCCDS0008
« Reply #7 on: April 13, 2011, 10:33:39 PM »
I've ridden a valk for close a 100 thousand miles now and still have trouble shifting from first to second once in a while. I found out if I'm tried or sleepy I miss shifts and sometimes the difference between the type of shoes I'm wearing seems to make a diffence. I have a kick shifter and if I pay attention when I'm shifting  I seldom miss a gear.
PhredValk
Edmonton, Alberta, Canada
« Reply #8 on: April 13, 2011, 11:39:14 PM »
Preload means putting some upward pressure on the shifter before you pull the clutch and reef it up. Helps sometimes.
Does she want to inch foreword in first with the clutch pulled tight? Might need some adjusting in the clutch action or lever if it isn't disengaging fully. Passing thru neutral with the clutch not fully disengaged could mess up the synchromesh...
Fred.
VRCCDS0237
« Reply #9 on: April 14, 2011, 06:39:17 AM »
I'll put my $$$$ on the old brown nag in the 5th race.
Take the clutch lever out and replace the bronze/brass sleeve.
Yours is probably EGG SHAPED.   Then replace the fluid in both the clutch and brakes.    You say why the brakes, it helps old farts later in the rear to try and remember which one did I replace.   Ya do all three at the same time, ya don't have to rack ur brain or look for your notes to determine which one ya did.
2nd gear is a known mis it if ya are a lazy shifter.   This old girl was built to slam the gears in place.   That is one reason I have a Chet's Kickshifter.    Ain't missed a gear since I installed it.    Prior to installation, I missed 2nd about 3 out of 10 shifts.......
bigfish_Oh
Allis
West Liberty,Ohio 43357
« Reply #10 on: April 14, 2011, 07:56:20 AM »
the dealer told me my new '79 750F shifted fine.. at under 2000 miles Honda paid for a new top end ($627)because of missed second gear shifts, it cost me 4 spark plugs. Of course it still missed second. Both of my CBX's had different quirks and would miss or hang up, fall out. I can associate one to "lazy" shift. I cured my '82 when the trans gears were back cut.  My brothers CBX nor friends Suzuki's never gave me any problems. My Valk will hang in a gear.
---I have never owned a Honda that shifted correct 95% of the time, 100% is outa the question
2012 HD Road King Classic, Teq sunrise/HD Orange
2009 HD Nightster,orange
1974 CB550F,org
1999 Valkyrie,orange/Black (20K)
2009 GMC 3500 Duramax CC Dually 4wd (new)
1957 WD45 Allis Chalmers Grandpa bought new
1982 CBX (new)
1980 CBX (6K)
1979 CB750F (new)
1958 Lambretta TV175 (Dad's new)
4
bigfish_Oh
Allis
« Reply #11 on: April 14, 2011, 08:02:22 AM »
kinda off topic, but since the title is "shifting to second"
Sometime 82-84(a lot of friends worked their) their was a misprint in a Honda car manual, "when shXXing from second to third" or something to that effect.
1974 CB550F,org
1982 CBX (new)
1980 CBX (6K)
1979 CB750F (new)
4
« Reply #12 on: April 14, 2011, 08:14:04 AM »
do a search as this has been address before.
main point is to rotate the shifter down one spline on its shaft. had similar shifting problems when it was brand new, rotated the shifter and never a problem since.
your brand of oil could also be causing the problems. smoothest shifting oil I have used is amsoil 10w30/30 HD diesel oil. it was orginally designed for wet clutches and use to carry the allison and cat specs for wet clutch transmissions when it was a straight 30w. still basically same oil except for temp ratings which affected the W classification
any 15w40 or 5w40 diesel oil would also be good to use
tybme
1999 Valkyrie I/S
Topeka KS
« Reply #13 on: April 14, 2011, 01:38:01 PM »
I 2nd the vote for moving the shifter one spline. My Valk does the same thing from our description - I have yet to take the time to move the shifter one spline but I feel that is going to be the correction for the issue.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways. totally worn out, shouting, "Holy ****... What a Ride!"
paps350
Pittsburgh Pa
« Reply #14 on: April 14, 2011, 02:44:15 PM »
I had the same trouble when I first bought my Valk. Depending on what type of footware I had on made a difference on how it would shift. With boots on no problem shifting but with a soft style tennis shoe ( I know who rides in tennis shoes) I repeatedly missed second gear. Moved shifter ons spline and made a bid difference you still will need to give it a good kick due to the long travel from first to second.
Valkpilot
What does the data say?
Corinth, Texas
« Reply #15 on: April 14, 2011, 05:01:11 PM »
I don't know, folks.  This description sounds like it needs more of a solution than just an authoritative shift.
Tibado, I'd follow the advice of those who advised that you check the lever, bushing, and bleed the clutch.
Bent shift forks seem to be something of a rarity.  If, after the above easy stuff, you still have problems and it includes not being able to pull the lever all the way to the grip, you might need to rebuild the clutch stack because the damper plate is falling apart.
« Last Edit: April 17, 2011, 09:33:52 AM by Valkpilot » Logged
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
« Reply #16 on: April 14, 2011, 06:06:07 PM »
Off topic but valkpiolot, love the saying under your avatar.  cooldude Thats my partners and I's fav movie and say that line at work anytime we can.
Walküre
Nothing beats a 6-pack!
Oxford, Indiana
« Reply #17 on: April 15, 2011, 02:05:37 AM »
And, now we know, too...   *wink, wink!!*
2000 Valkyrie Standard
1999 Valkyrie Interstate
2000 HD Dyna Wide Glide FXDWG
Roger Phillips
Oxford, IN
VRCC #31978
Yeah, what she said...
Quicksilver
Norway Bay, Quebec, Canada
« Reply #18 on: April 15, 2011, 02:42:03 AM »
Recently changed oil seal on shifter. Found i had replaced shifter at wrong position and I could downshift but not up shift. Shifter was contacting frame on the up stroke. There are 2 adjustment points. The spline right at the motor and the spline at the end of the shaft that extends out and your arm attaches to. I rotated the entire assembly on the inner spline to give me clearance at the frame and then adjusted the arm to the correct level for my boot to get under. Works well now, I used to miss the odd shift and I think that it was set too high at the motor to begin with.
1997  Standard
Valkpilot
Corinth, Texas
« Reply #19 on: April 15, 2011, 04:21:03 AM »
Thanks, Fudgie!
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Mo Lee
Waynesville, Mo
« Reply #20 on: April 15, 2011, 04:11:40 PM »
My 97 with 73000 miles seems to miss second quite often usually when I am making noise showing off. It also does not want to downshift to first without grinding while moving. On the other hand my 03 with 10000 miles always shifts smooth and seldom misses second except when I'm lazy shifting. I figured the 97 was just worn and may need a teardown someday. Reading this thread maybe I will try some options first.
« Reply #21 on: April 17, 2011, 06:08:17 AM »
Can someone point out where this brass bushing is to check? Had the lever off but could not tell where it was at.
MP
North Dakota
« Reply #22 on: April 17, 2011, 06:11:21 AM »
It should stay inside of the lever.  May need to be pressed out.  The pin goes thru it to hold the lever on.
 This wears as you use the lever.  Then, instead of having to replace the whole lever when it wears, you just replace the bushing.  Plus, the bushing wears better than the aluminum lever.
MP
"Ridin' with Cycho"
« Reply #23 on: April 17, 2011, 06:15:32 AM »
MP
Oh, ok. Boy I feel silly.  Embarrassed
« Reply #24 on: April 17, 2011, 09:06:37 AM »
The pivot points on the handlebar levers are exposed to the elements and especially riding in the rain.
A little shot of oil every now and then does wonders to maintaining their good working condition.
Ignoring this basic preventive maintenance measure along with some of the other basic and easy to do things will condemn a rider to always having to worry about this thing or that!
Seems there's a lot wanting (only) to do all the "mods" with little attention given to preventive maintenance issues.
Jus sayin!
