February 02, 2026, 06:29:24 AM *
Author Topic: rasing fuel tanks  (Read 2489 times)
nugz
Sturgis SD
« on: April 15, 2011, 11:54:14 AM »
seen on here people talking about raising fuel tanks. was wondering what this means and intales, and if really does help. all info would be great.
nugs
sturgis sd
Nugz
Chiefy
Sarasota, Florida
« Reply #1 on: April 15, 2011, 12:06:10 PM »
While we're on the subject, do you raise the tank front and rear?  If front only, how does that effect miles to reserve?
« Reply #2 on: April 15, 2011, 12:06:27 PM »
Here's a spacer for raising the Tank that allows you to put those "stacks" on your
carb tops without worrying about them hitting your tank... the stacks are just for looks,
but BigBF sez the spacer also improves air flow into the air box...
http://www.bigbf.com/bigbf_shop/sale/v-stack/index.htm
Red Diamond
Beaumont, Texas
« Reply #3 on: April 15, 2011, 12:54:25 PM »
nugs
sturgis sd
It helps you to see that big shiny chrome gas cap better and put the glare from the sun directly into you eyes. Other than that, nothing.
roboto65
Conroe,TX
« Reply #4 on: April 15, 2011, 06:59:48 PM »
So it takes it from the windshield and puts it in your eyes Hey I am in  2funny 2funny crazy2
Allen Rugg
VRCC #30806
1978 Kawasaki KZ 650 project
greggh
OMAHA NE
« Reply #5 on: April 15, 2011, 08:03:02 PM »
IF you are raising the tank to give clearance from the V-Stacks the above is a great addition.
Keep in mind that if you raise the tank for what ever reason, the tank will no longer be supported underneath where the rubber supports are attached to the frame under the tank.  There for putting possible stress on the front or rear mounting positions of the tank.  I use the spacer to gain clearance over the V-Stacks and I also took an old radiator hose cut to size and zip tied it to the frame under the tank to allow for the missing support.
Yes the space gives more air to the Air cleaner, have not noticed any difference from my bike to my friends Valk if I hit Reserve earlier or not.  Mileage varies from 19 mpg to 41 mpg.  It all depends on demand of the throttle.
mirion
1997 Std - 2000 IS
Frankenmuth, Michigan
« Reply #6 on: April 16, 2011, 08:59:54 PM »
I recently submitted an article to Shoptalk on a simple way to fix the rocking tank problem caused by the spacer under the front of the tank.
http://www.valkyrieriders.com/shoptalk/vstackspacermod.pdf
X Ring
VRCC #27389, VRCCDS #204
« Reply #7 on: April 16, 2011, 10:44:16 PM »
Outstanding mod  cooldude  Where did you find the rubber?
Marty
Kymbo
South Australia
« Reply #8 on: April 17, 2011, 12:30:46 AM »
Used this system and must say it worked great thanks for posting
mirion
1997 Std - 2000 IS
« Reply #9 on: April 17, 2011, 02:37:01 PM »
I found the 1/8 thick neoprene at work in a sheet material, we use it for gaskets and such. Here in Michigan it can be purchased at a place called Exotic Rubber and Plastic, (no, its not a kinky type place but an actual automotive supplier of all things that seal)
John U.
Southern Delaware
« Reply #10 on: April 17, 2011, 04:30:56 PM »
Looks like a piece cut out of the sidewall of an old car tire would work.
I wonder about the longevity of superglue though. My experience with it is that it works real well for a while, but after a year or two it lets go. That should only be a potential problem during tank removals. Once the tank is mounted, the rubber isn't likely to fall off.
Thanks for the idea, it beats my solution: cut up pieces of a swimming pool "noodle" that kids play with.
Blackduck
West Australia
« Reply #11 on: April 17, 2011, 04:37:12 PM »
I just used a couple of pieces of heater hose zip tied to the existing pads
« Reply #12 on: April 18, 2011, 05:54:32 PM »
     As far as the effectiveness of raising the tank for more air, it does work. When I first installed a carbon fiber Supertank years ago the bike would run fine until under a load at higher rpms. Then it was like the choke was on , black smoke and no power. Shimmed the front of the tank with a couple of extra rubber tank mount spacers and problem solved. Not sure it would help with any power increase with a Honda tank but more air will be diverted under the tank.
