February 02, 2026, 06:28:38 AM *
Author Topic: Riser question  (Read 2829 times)
f6rider
« on: April 15, 2011, 06:29:20 PM »
I have a handle bar riser question. I would like my bars to come back a couple of inches.
Maybe a little of Handle bar risers 101 would be in order
Thanks John Wodarski
John U.
Southern Delaware
« Reply #1 on: April 15, 2011, 07:48:17 PM »
I can tell you that in the Riser department, a little goes a long way. 2 inches additional pullback may be above the limit without extending cables. Our risers are metric of course, the Harley risers will fit if you drill out the holes a bit.
Check out these, they are about as extended as allowed with stock cables, and they cover up the circular depressions in the top of the tripletree :http://www.hondadirectlineofshadyside.com/stores/product.asp?pid=519&str=2&ID=69527554
Russell Rice
I think I can, I think I can, I think I can!
Owasso, Oklahoma
« Reply #2 on: April 15, 2011, 07:53:41 PM »
Harley duce risers works great for me and it only requires about half a beer worth of work to install them. You have to grind or cut the little ring off on the bottom of the risers so they sit flat on your triple tree and you have to drill the mounting holes out to 1/2 inch and buy some grade 8 1/2 inch bolts to install them with. I also bought the interstate throttle housing so the throttle cables would come out the bottom instead of the top. That gave me enough length on the cables so I did not have to buy longer cables.  cooldude
X Ring
VRCC #27389, VRCCDS #204
« Reply #3 on: April 15, 2011, 08:41:17 PM »
Was this what you were trying to link to?  http://directlineparts.com/product.asp?pid=519&str=2
Marty
John U.
Southern Delaware
« Reply #4 on: April 15, 2011, 09:00:25 PM »
Yup!
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #5 on: April 15, 2011, 09:19:21 PM »
f6rider.....why don't you look at xf6-custom.com.  look at his 4 inch risers...i have them on both of my bikes...yes they are 4 inch straight, but when mounted you have alot of cable room to play with, and all you have to do is turn the handlebars back toward you and they fit perfectly.  i have had the others, and these do the pull back better, and more comfortable.  just give daryl a call.
bassman
« Reply #6 on: April 16, 2011, 04:30:01 AM »
OK  a "little risers 101" for ya..... cooldude
http://www.timskelton.com/valkyrie/how_to/risers.htm
Daniel Meyer
The State of confusion.
« Reply #7 on: April 16, 2011, 07:07:18 AM »
Good info but do not buy those in the picture and if you have them, replace them with a better design.
Here's why (both short articles with pics):
http://lifeisaroad.com/blog/2009/05/05/wellthats-not-good/
http://lifeisaroad.com/blog/2009/05/19/annnd-nobody-died/
When this happens the handlebars fall...not a good thing when you are riding.
Nearly killed me.
CUAgain,
Daniel Meyer
Chiefy
Sarasota, Florida
« Reply #8 on: April 16, 2011, 07:17:10 AM »
I bought these on eBay: http://cgi.ebay.com/ebaymotors/Honda-Valkyrie-GL1500-Gl-1500-Handlebar-Risers-_W0QQcmdZViewItemQQhashZitem2eb48469feQQitemZ200597072382QQptZMotorcyclesQ5fPartsQ5fAccessories#ht_1026wt_958
I was hoping risers would help with my tendinitis and carpal tunnel.   Didn't want to spend a lot of money and find it didn't, or was even worse.  Anyway, they helped a lot, and are cheap.  Of course, they don't look as good as replacing the stocks with a new pair either, but you don't notice unless you stick your face in the area.  And these did not require moving the cables at all.
« Reply #9 on: April 16, 2011, 01:41:47 PM »
Have you tried a Throttle Rocker yet? Allows you to rest your grip and use the presure of your wrist instead to hold the throttle on.
Chiefy
Sarasota, Florida
« Reply #10 on: April 16, 2011, 01:46:32 PM »
Have a TR on the trike, and the Dragon had the Kury thingy on it.  Didn't like the Kury much, but after having it for awhile, I prefer it over the TR.
BIG COUNTRY 23321
Me & My Death Horse
Chesapeake, Virginia
« Reply #11 on: April 16, 2011, 03:48:22 PM »
+ 1 for what Goose Said. I have the 4 inch Pullback risers from XF6 and did not have to do anything for the cables and it fits Perfect!!!! I like them a whole lot better than stock !!!!
Farther
Quimper Peninsula, WA
« Reply #12 on: April 16, 2011, 03:55:02 PM »
+1, I don't think there is an easier or more cost efficient way to modify your risers than with these extentions.
~Farther
f6rider
« Reply #13 on: April 16, 2011, 04:42:18 PM »
this is a follow up question for goose, chiefy, and big country.
What are your measurements? I am 5 11 300lbs with a 30 inch inseam.
I want them back farther for handling reasons..
thanks all who responded
BIG COUNTRY 23321
Me & My Death Horse
« Reply #14 on: April 16, 2011, 05:03:02 PM »
Asking such personal questions and you havent even taken me out for dinner or a movie yet!!!!!! For Shame. I am 6'6" Tall and 350 pounds with 32 inch Inseam. There is a Reason I am Called Big Country !!!!
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #15 on: April 16, 2011, 07:26:53 PM »
i'm not big enough yet where i need a bigger bike. 5'9'' 225 29 inseam....these risers will do exactly what you are looking for them to do.  they are 4'' straight risers, but when you get them on with the handlebars mounted, and you drop the bars down toward you...you will be amazed....there is plenty of play left in the cables, and you can have the bars right where you want with comfort.
Chiefy
Sarasota, Florida
« Reply #16 on: April 16, 2011, 07:31:32 PM »
5' 10" (and a half)  Plus 9 in (never mind)  31" inseam.  240 lbs.
PhredValk
Edmonton, Alberta, Canada
« Reply #17 on: April 17, 2011, 11:48:03 AM »
I know how expensive all this crap is (I have a pile of mailers and UPS boxes in the basement waiting for spring), but if comfort is more important than money you may want to remember that you don't have to stay with the stock hadlebars and cables.
Several members here have posted threads showing other bars with totally different configurations on their bikes, from drag bars to Harley-type setups. Maybe a change in grip angles and bar width will help with the pain.
Fred.
VRCCDS0237
