February 02, 2026, 06:29:28 AM *
Author Topic: Question about fork oil  (Read 2016 times)
rainman
Steve ( rainman) Eads
Bloomington Indiana
« on: April 18, 2011, 04:06:37 PM »
My local honda dealer doesn't know what weight of oil to sell me for the valk. Question is can you still use AFT automatic transmission fluid like we did in to old days or should I just take what the dealer sells me.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #1 on: April 18, 2011, 04:27:20 PM »
ATF is about 8wt oil. I run 15 wt fork oil in the compression fork leg and 10 wt in the rebound side. I am 300 lbs and ride heavily laden frequently. I also ride hard.
Anthony
Belgium
« Reply #2 on: April 18, 2011, 04:27:44 PM »
Honda manual says :
Pro Honda Suspension fluid SS8
I used W10, fork oil of the brand the dealer had on hand.
Anthony
« Reply #3 on: April 18, 2011, 04:28:48 PM »
When I put 15 wt in after replacing my seals, I noticed the forks were considerably stiffer, especially in cold temperatures.  They also don't collapse like they used to when getting on the front brakes quickly.
rainman
Bloomington Indiana
« Reply #4 on: April 18, 2011, 04:48:09 PM »
Thanks guys  cooldude
« Reply #5 on: April 19, 2011, 07:59:06 AM »
I went out and measured the travel of the forks on my Interstate.
4" travel, top to bottom.
Bad On 3
RIDIN THE BEAST ! !
CHICAGO IL. 60638
« Reply #6 on: April 19, 2011, 05:06:10 PM »
OK i have a question  this honda dealer dont know it 8 weight oil --ooo boy  if you want to stiffin it up go to 10 or alittle higher ---i hope you dont let this dealer work on your bike !!!!!! crazy2
Ridin Down The Road Of Life With My Friends !! What a Ride !!
rainman
Bloomington Indiana
« Reply #7 on: April 21, 2011, 04:37:47 AM »
No I am going to starting the job today around 9:00am I got 10w oil I think the kid I was talking to was new and he did want me to know that he was new. when I got to the dealer they knew what I needed.  So now I am ready for the fuuuuuuuun.
But I think the next time I have do a seal job I will be using ATF
thanks again to all of you.
« Reply #8 on: April 21, 2011, 04:53:51 AM »
As far as I know, they come come initially with 10 wgt.. Lighter oil will lighten the front end and heavier oil will stiffen it.. ATF is generally 7.5 wgt..
