February 02, 2026, 06:29:33 AM *
Author Topic: Clutch Fluid  (Read 1938 times)
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« on: April 18, 2011, 05:56:18 PM »
Went for a ride and notice it not shifting very smooth.  When going into the next gear it sometimes felt like more of an effort to grab the next gear.  I figured it was time for a fluid change so when taking off the cover I noticed the resevoir was down about a 1/3.
I have not had a chance to ride it since the change.
Here are my questions.
If it is low on fluid how does a valk act?
Dropbox is a neat app I found that I use to store files and pictures of my Valk.
olddog1946
Moses Lake, Wa
« Reply #1 on: April 18, 2011, 06:04:15 PM »
Just like any clutch that is not disengaging..it will drag and shift hard..
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #2 on: April 18, 2011, 06:39:38 PM »
I've seen posts here before that to make it easier on your brain change all brake and clutch fluids at the same time, it worked well for me.
Safe Riding
Michael cooldude
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
PhredValk
Edmonton, Alberta, Canada
« Reply #3 on: April 18, 2011, 09:42:05 PM »
The box on the handlebar is a reservoir, extra fluid, a safety measure. It's the fluid in the piston and line that makes the clutch work. It's being down that far may point to a problem in the system, but shouldn't make it hard to clutch. Probably air or moisture in the fluid. A change sould take care of your problems.
Change brake and clutch fluid every year or two.
Fred.
VRCCDS0237
olddog1946
Moses Lake, Wa
« Reply #4 on: April 19, 2011, 02:39:58 AM »
Fred.
Fred, the piston to push the fluid to release the clutch is in the reservoir,,,being low on fluid, he may be trying to squeeze air (which will compress) instead of fluid (which doesn't) therefore,,,dragging clutch.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
« Reply #5 on: April 19, 2011, 07:17:10 AM »
There will be no change to the clutch operation just because the fluid level is low UNLESS...it gets low enough to let air in the line. Now you will have problems, SO just adding fluid (if air got in the line) will not fix it, you must bleed that line to get the air out.
