February 02, 2026, 06:29:37 AM *
Author Topic: Oil technically speaking  (Read 2741 times)
« on: April 19, 2011, 04:37:20 PM »
Alright.......we had a discussion a while back about a friend of mine that ended up with an over filled Valkyrie crankcase.  As reported to me at the time, he dumped in 4 qts as he always did and thought he was good.
Turns out he bought oil at a different place and didnt notice the jugs were 1L jugs instead of 1qt.  OK, so that explains that.......BUT.......
Today I did an oil change.  Oil change #3 since changing to Mobile 1 in the 5qt jugs.  OK, unless my math really stinks......3X using 4 out of 5 qts should leave me with 3 qts left over after all is said and done.  Two times doing it.....2 qts left over.
So the first time:
-I measured 4 qts out of the 5qt jug, put the rest up (UNMEASURED)
The second time
-I did the same then poured the remaining in with the first jug.  So that should be around 2qts in that jug (STILL UNMEASURED)
Today:
-I use the old jug first and out comes 1qt, then 2qts, then 12oz more.  So between the first two jugs there was an average of 6oz EXTRA, yep free oil! can you believe it.  So, even though my friend misread, my original warning is valid.  Dont trust the big jugs like you do the qt jugs........there can be extra.
and just because I wanted to be anal this time.....I actually pulled out the dipstick and it was perfect to the line as always with exactly 4 qts
vanagon40
Greenwood, IN
« Reply #1 on: April 19, 2011, 07:05:55 PM »
I don't want to start a flame war here, but I still have a hard time believing that quality (or QUANTITY) control is so lacking that the oil companies are adding almost 5% extra.  My reasoning is (in part) that my daughter works as an engineer for General Mills (they make Cheerios among other products).  She tells me that General Mills overfills their cereal boxes by tenths of a percent, to ensure that no product is underweight.  She also tells me that if there was a way to increase the accuracy of the filling process to reduce the overfill by even one tenth of one percent, it would amount to savings in the millions of dollars.
Now, my daughter told me this one or two years ago, so I may be slightly misrepresenting the exact numbers.  But, I am sure the overfill was nowhere near 5%.  Additionally, I would think it would be even easier to be more precise on a fluid such as engine oil as compared to Lucky Charms.
I also remember that I once mated two 1 quart bottle caps together using JB Weld and drilled out the centers.  I would then screw two "empty" oil bottles together so one "empty" bottle could drain into the bottom bottle and I collected what seemed to me to be quite a bit of oil from the "empty" bottles.  However, I admit that this phenomenon would not account for 6 ounces clinging to the walls of a gallon (or 5 quart) bottle.
flcjr
Manhattan,Montana
« Reply #2 on: April 19, 2011, 07:49:28 PM »
I believe this is much to do about nothing Please go ride your bike and clear your head. Grin On the other hand I don't think Mobil is giving away that much oil if they are I am going to start buying more of it.I think we all need better weather to ride are valks and quit coming up with these things in are free time. Grin  Grin I then when not have any free time to respond and problem solved (at lest for me)
« Reply #3 on: April 19, 2011, 10:17:00 PM »
I run into these kinds of measure amount all the time in Canada.
A US gal jug of milk (3.7 Liters) is labeled as 4 Liters of milk. 1 qt bottles labeled as 1 liter.
I think you might have gotten a 4 Liter jug of oil, that was labeled as 4 qts. Most likely you have paid for the actual amount of oil (4L) in the jug, but have been mistakenly told there was less there.
Walküre
Nothing beats a 6-pack!
Oxford, Indiana
« Reply #4 on: April 20, 2011, 01:27:48 AM »
Just came in from checking my jugs...seems between two of them, I'm 12 oz. short...do you need my address to send it to me??
R
2000 Valkyrie Standard
1999 Valkyrie Interstate
2000 HD Dyna Wide Glide FXDWG
Roger Phillips
Oxford, IN
VRCC #31978
Yeah, what she said...
« Reply #5 on: April 20, 2011, 05:46:31 AM »
LOL....at least some have a sense of humor.......I agree,its not a big deal (unless it becomes one)....I guess there were always things that you could count on, and then all of a sudden you cant anymore........as always if you really couldnt care less and this bothers you, there is the "back away" button   just back away and move on......at least there are no naked big hairy guys and no one was harmed in the making of this post.   Grin
Thats all I have to say about that
« Reply #6 on: April 20, 2011, 06:08:21 AM »
R
yes I would need your address, but due to HomeLand Security policy I can only send less than 1oz at a time....so Ill have to sent 15 or so ziploc baggies full of oil over a extended period of time so we dont alert the terror watch folks.   2funny
Walküre
Oxford, Indiana
« Reply #7 on: April 20, 2011, 06:12:27 AM »
Roger Phillips
Oxford, IN
VRCC #31978
« Reply #8 on: April 20, 2011, 06:49:01 AM »
I know-i know apples and oranges. Actually oil and taters. Back in the 70s when i was hauling produce- i hauled an awful lot of potatos out of colorado. I had more than one grower tell me that a 100# sack of spuds had to weigh in(at the rcvr) between 103#to 105#- or the load would be turned down. I did run into that turned down crap more than once at Safeway in dallas tx. I know-not oil or valk related. But on another note the weather is crappy here in the ozarks this day. RIDE SAFE.
Red Diamond
Beaumont, Texas
« Reply #9 on: April 20, 2011, 01:34:09 PM »
Hey Chris, you posted the above post, at the end, you stated, " thats all I have to say about that"
R
Now this, I really don't think you can quit can you? Keep posting!!!!!!!!!!LOL
Bobbo
Saint Charles, MO
« Reply #10 on: April 20, 2011, 02:46:36 PM »
Maybe you should buy another 5 quart jug, and measure it directly.  That would put the matter to bed much better than all this indirect stuff.
flcjr
Manhattan,Montana
« Reply #11 on: April 20, 2011, 06:40:07 PM »
 crazy2 I cannot believe I am responding to this again the weather is still not nice enough to go for a ride and I am stuck inside reading this. tickedoff  Grin
smurf
west central wisconsin
« Reply #12 on: April 20, 2011, 10:51:14 PM »
as for the confusion on the amounts as far as i know the bottles are filled by weight not volume..when i buy bulk oil it come in a 55 gal drum.. i get the same oil in the same type of barel..and when i look inside its never at the same height...cant explain it other than it depends on the manufactures run that day....
bigguy
VRCC# 30728
Texarkana, TX
« Reply #13 on: April 21, 2011, 06:31:10 AM »
Ha ha! This is the strangest "oil" thread I've every read.  Cheesy Usally it's all about full or semi synthetic. Mobile 1 or Royal purple. The weather must be really bad outside. Grin
Here there be Dragons.
flcjr
Manhattan,Montana
« Reply #14 on: April 21, 2011, 02:00:51 PM »
I wish the weather would full or semi change so we can all go on a Royal ride and be Mobile on our valks. crazy2     does this help?
« Reply #15 on: April 21, 2011, 03:30:12 PM »
    cooldude cooldude cooldude cooldude cooldude cooldude cooldude cooldude cooldude cooldude cooldude cooldude cooldude cooldude 2funny 2funny 2funny crazy2 uglystupid2
