February 02, 2026, 06:28:44 AM *
Author Topic: Car Tire Mounted  (Read 3014 times)
G-Man
White Plains, NY
« on: April 21, 2011, 10:45:29 AM »
Noticed about 3/8" of the tires bead extends past the edge of the rim all the way around on both sides.  Tech said he used a lot of bead lock, but wanted to bring my attention to it.
Goodyear Triple Tread.  Normal?
« Last Edit: April 25, 2011, 08:17:23 AM by G-Man » Logged
Valker
Wahoo!!!!
Texas Panhandle
« Reply #1 on: April 21, 2011, 12:08:03 PM »
Stupid question (my normal) but are you sure it's a 16" tire? They are available in lots of sizes.
Ferris Leets
Catskill Mountains, N.Y.
« Reply #2 on: April 21, 2011, 12:27:50 PM »
I took my car to a Sears one time to have tires mounted.  When I got back the kid said he could not get them on the rims.  I looked and he was trying to put 14" tires on my 15" rims.
G-Man
White Plains, NY
« Reply #3 on: April 21, 2011, 12:49:31 PM »
It's a 16" tire.  If you look at the letter "L" and imagine that the wheel is the verticle part of the "L".  The 1/4" to 3/8" I'm referring to would be the horizontal part of the "L".  What concerns me is how much of the verticle part of the "L" is inside of the wheel.
wizard -vrccds#125
Hitchcock Tx.
« Reply #4 on: April 21, 2011, 04:33:00 PM »
Need a photo !!!!!!! you "L" don't get it ?
Daniel Meyer
The State of confusion.
« Reply #5 on: April 21, 2011, 04:59:13 PM »
Yeah, need a photo. The bead won't show if the tire is the right size. I'd guess your tech may not know what he's looking out or he's trying to alarm you.
The bead mating area on the rim is identical to the 16" mag wheels on the wife's car.
CUAgain,
Daniel Meyer
« Reply #6 on: April 21, 2011, 05:14:17 PM »
What is the tire size on the tire.   Not what you ordered from them, but the actual size off of the tire.
Sounds like it might be an off breed size.
Daniel Meyer
« Reply #7 on: April 22, 2011, 06:23:46 AM »
The TT has a substantial standout immediately from the rim. Many modern tires do to protect the rim from curbs and such...
CUAgain,
Daniel Meyer
G-Man
White Plains, NY
« Reply #8 on: April 22, 2011, 08:22:41 AM »
Thank you Dan!!!  You figured out my concern.  Yes, the wheel looks like it sits in about 1/4" or a little more.
What is the width of our rear wheel?  According to the GoodYear site, the tire is approved for a wheel width of 5.5" to 7.5".
Daniel Meyer
« Reply #9 on: April 22, 2011, 08:24:50 AM »
Our wheel is 5".
CUAgain,
Daniel Meyer
« Reply #10 on: April 22, 2011, 06:30:09 PM »
I believe he is referring to the step out. After mounting my TT to rim, it looked like it was bent inwards a little, and was very deeply off set. Would make sense that there is about 1/4" rim outside of the rim of the wheel.
« Last Edit: April 22, 2011, 06:58:45 PM by gordonv » Logged
DFragn
« Reply #11 on: April 23, 2011, 04:34:02 AM »
G-Man
Daniel is spot-on. That lip or stand out is the rim protector for car rims. See pic. lip is more visible here at the 2-3 o'clock position.
However, the 5" rim width he mentioned is more like the front rim, the rear rim is somewhere around 7". Note 2" wide blue tape over the inside of my air valve.
You'll be fine...I had the same question/doubt the first time I mounted my GY TT
« Last Edit: April 23, 2011, 04:36:18 AM by DFragn » Logged
G-Man
White Plains, NY
« Reply #12 on: April 25, 2011, 06:47:36 AM »
G-Man
Thank you, Brother, I really was concerned.  The tech made me sign a waiver and everything.
Here is a pic of my thingy:
Daniel Meyer
« Reply #13 on: April 25, 2011, 08:29:11 AM »
Yeah, that's not the bead. Perfectly normal for an assurance TT, and most of the yokahomas I've seen.
Tech should have looked closer at the tire before he installed it.
CUAgain,
Daniel Meyer
G-Man
White Plains, NY
« Reply #14 on: April 25, 2011, 09:52:08 AM »
Thanks, Dan!
eric in md
« Reply #15 on: April 25, 2011, 09:59:24 AM »
g man your safe .. mine looks like that at 23 thousand miles later ..  cooldude
Kaiser
Gainesville, FL
« Reply #16 on: April 25, 2011, 11:02:29 AM »
And that right there, ladies and gentlemen, is when I quit reading this thread.  Evil 2funny
MP
North Dakota
« Reply #17 on: April 25, 2011, 11:35:15 AM »
I was going to say something, but I could not figure out what, and still remain as a member of the forum!  Admin frowns on that stuff!  LOL   Grin
MP
"Ridin' with Cycho"
sugerbear
wentzville mo
« Reply #18 on: April 25, 2011, 11:41:30 AM »
i thought the rim was 6 in, but couldn't find the spec in the manual.
