« on: April 21, 2011, 02:56:45 PM » |
Without taking my bag support off on one side to find out, can someone tell me if I'm correct here: the front bolt is 10mmx1.25 thread, the rear bolt is 8mmx1.50 thread. Not concerned with length at the moment, just the thread....I know the diameter is correct. I have some of each around here....somewhere. Yet to be located so will go shopping tomorrow.
Joe Hummer
Arnold, MO
« Reply #1 on: April 21, 2011, 03:11:51 PM » |
1999 Valkyrie Interstate You pay for the whole bike, why not use it Jerry Motorman Palladino
Oyeaa
« Reply #2 on: April 21, 2011, 03:20:34 PM » |
Without taking my bag support off on one side to find out, can someone tell me if I'm correct here: the front bolt is 10mmx1.25 thread, the rear bolt is 8mmx1.50 thread. Not concerned with length at the moment, just the thread....I know the diameter is correct. I have some of each around here....somewhere. Yet to be located so will go shopping tomorrow.  Yep it is 10mmx1.25 thread.
Redline +
« Reply #3 on: April 21, 2011, 07:45:35 PM » |
Without taking my bag support off on one side to find out, can someone tell me if I'm correct here: the front bolt is 10mmx1.25 thread, the rear bolt is 8mmx1.50 thread. Not concerned with length at the moment, just the thread....I know the diameter is correct. I have some of each around here....somewhere. Yet to be located so will go shopping tomorrow.  You're close John, 10 x 1.25 and 8 x 1.25. Redline
Anthony
« Reply #4 on: April 22, 2011, 01:36:30 PM » |
when i needed those bolts, longer then standard, i found that front bolt M10x1,25 was very hard to get. i ended up buying a box of 100pcs M10x1,25x80mm, just cause i needed 2pc.
so, if you need any, and can wait till i get back to my garage (2weeks ) , i can put some in the mail. send me a pm with address and i'll post them.
plain steel, not galvanised.
Anthony
Sodbuster
« Reply #5 on: April 23, 2011, 05:25:02 AM » |
Also, try giving HitchDoc a call .... they have nice chrome bolts in the longer lengths !! http://www.hitchdoc.com/motorcyclehitches.php
VRCC # 30938 '99 Std. - Black & Silver - "Spirit Horse" Dear God, Seriously .... Thanks for creating beer. You rock !!
wiggydotcom
Yorkville, Illinois
« Reply #6 on: April 23, 2011, 07:30:52 AM » |
If my thinking is straight...8x1.25 is coarse thread, while 10x1.25 is fine thread and yes, it's very difficult to find. I finally ordered a 1 meter length of 10x1.25 galvanized through a local Fastenal dealer.
Can anybody tell me what a good length is to cut both the 8mm and 10mm to for the bag quick drop conversion? Thanks in advance.
VRCC #10177 VRCCDS #239
« Reply #7 on: April 23, 2011, 08:18:36 AM » |
The problem of availability is easily solved by using SAE size bolts and nuts.
Especially if you've done the nut cage modification.
Regardless, it's pretty simple to replace the nuts on the inside, and finding chrome bolts in SAE size is very easy.
Sodbuster
« Reply #8 on: April 23, 2011, 11:03:03 AM » |
...... Regardless, it's pretty simple to replace the nuts on the inside, and finding chrome bolts in SAE size is very easy That's a good idea !!
Anthony
« Reply #9 on: May 06, 2011, 10:17:45 AM » |
The M10 has a nut welded into the front part of the rear fender, so you would first have to drill it out completely and then tap new bigger thread into it...: M12 Or you would have to grind that nut completely off first.
Anthony
