February 02, 2026, 06:28:45 AM *
Author Topic: I can't get it started !  (Read 1910 times)
Sailor
« on: April 21, 2011, 09:47:13 PM »
Hey I just changed my radiator on my 2000 Valkyrie and I hooked all the fuel lines back up, step by step like my Clymer manuel said to but I can not get it started. the engine turns over bot it won't fire. I was wondering is there something I need to do to prime the system? flush the system? is the gas to old ? I dpn't think its the spark plugs but I haven't tested them yet. any hints out there I would be greatful.
Sailor
Bone
« Reply #1 on: April 22, 2011, 04:40:59 AM »
How long since the bike has run ? Weak batteries discharge quickly. They will crank the engine fast but not have enough volts for firing the spark plugs. Jump it off of a non running car to try and eliminate one possible problem.
lucky_1_chris
Arlington, TX
« Reply #2 on: April 22, 2011, 09:05:55 AM »
Also make sure you hooked the vacuum line back up to the petcock.
1999 Valkyrie Interstate
bigdog99
1/1/2011 86,000 miles
Kouts Indiana
« Reply #3 on: April 22, 2011, 09:16:36 AM »
+1 on that, it will not start with that vacuum hose from #6 carb to the pet rooster. make sure its tight too.
VRCC#31391
VRCCDS0239
« Reply #4 on: April 22, 2011, 09:49:59 AM »
I guess my first question would be....if all you did was change out the radiator, why does that have anything to do with the carbs?  You don't need to touch them if the radiator is all you changed, unless your question is only a portion of what was done.
bigdog99
Kouts Indiana
« Reply #5 on: April 22, 2011, 03:18:17 PM »
"changed my radiator "......"hooked all the fuel lines back up"
i love it when the onion is peeled.  Grin cooldude
VRCC#31391
VRCCDS0239
