February 02, 2026, 06:28:47 AM *
Author Topic: Sanding National bags  (Read 1495 times)
« on: April 23, 2011, 09:42:19 AM »
Does anyone have any experience with sanding National Bags?  Yesterday the latches let go on one of them, and it skidded down the road, scratched it up.  The bags are like $700 - man they went up.  I think they might be ABS plastic but I'm not sure.  I also think they have impregnated color.  So it might be possible to sand them down to a smooth surface.  Haven't done this with plastic, but I expect it will have to be wet sanded, can't use power, melting is an issue preventing high speed sanding and buffing.
DFragn
« Reply #1 on: April 23, 2011, 10:36:20 AM »
Yep, did pods & fairing for my Tourer.
Firstly, use a degreaser / wax remover before you sand anything otherwise you'll embed wax or grease into the surface which will effect re-paint.
Sand [WET] start with 6-800 grit and finish prep for paint with 1500 at least. All irregularities left behind will show through primer, paint & clear. I don't like filler primer's.
For pin holes & light scratches that remain you can use 3M's Acryl-Green Spot Putty #05960 and sand it down.
For deep scratches and gouges use body filler.
I rattle can painted [Colorite] these parts.
If you do the paint, and have questions, give me a shout.
Can anyone paint, maybe not. But, the last vehicle paint I did with a rattle can was in the early 70's. My 10 Speed, well let's say I couldn't wait to replace it with a car!
And I screwed up my dad's new Impala where I had run into it with said 10 Speed before he got home. I believe the entire sub-division went on vacation that week. Sheet hit the fan good.
I'm sure you could do it. You've got natural abilities.
But, count on painting the entire piece whether it's the bucket or the lid. If the color is not factory you'll have to have it matched and use professional spray equipment. That's OK, but adding the hardeners has to be right.
Custom color rattle cans would be extremely costly if at all possible.
Prepare yourself, getting an excellent final result requires huge amounts of sanding at every step including final clear coat finish sanding, polishing & waxing.
P.S. You can lightly wet sand the primer, especially if it's a little fuzzy, but never sand the color coats. Leave your finish sanding for the clear coat.
You can spray over gel coat too following good prep work.
« Last Edit: April 23, 2011, 10:43:40 AM by DFragn » Logged
9Ball
« Reply #2 on: April 23, 2011, 10:39:56 AM »
I believe they are gel coated...if the scratches are very deep you may not be able to just buff them out.  The bags are ABS to the best of my knowledge.
I had mine painted by R-Good's auto shop (does lots of work on higher end sports cars..Porsche, etc) just off Federal near 71st.  They block sanded mine as a prep for primer, then paint matched for my standard.
« Last Edit: April 23, 2011, 10:52:50 AM by jrhorton » Logged
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
