February 02, 2026, 06:29:28 AM *
Author Topic: darkside tire fitment  (Read 1861 times)
blackcat
Nicholas Vore VRCC # 30301
Mounds, Arkansas
« on: April 23, 2011, 03:41:22 PM »
i am wanting to install a 205-65 Falken Ziex 512, will i have any trouble with the tire rubbing with 12.5" 440 progressive shocks
the fender bolts are already cut and nut cages removed from running a 205-60 before
blackcat
« Last Edit: April 23, 2011, 03:49:12 PM by blackcat » Logged
______________________
03 Standard -Fast Black
00 Interstate - Red/Black
97 Tourstate - Yellow/Ivory
2010 Goldwing - Pearl Yellow
X Ring
VRCC #27389, VRCCDS #204
« Reply #1 on: April 23, 2011, 04:11:11 PM »
Have you checked to see if you have any evidence of rubbing with your 60 series tire?  If you do, you'll have more with the 65.  I run a 65 with I/S shocks on my 97 Tourer and have only had a problem with someone on the back and I forgot to adjust the shocks beforehand.
Marty
Tropic traveler
Silver Springs, Florida
« Reply #2 on: April 23, 2011, 06:46:56 PM »
205/65 Michelin HydroEdge & I had to do the nutcage mod. It is very close to the swingarm as well, not touching but close.
28 psi on a 1999 Standard with bags added & stock shocks.
'13 F6B red for Kim
blackcat
Mounds, Arkansas
« Reply #3 on: April 24, 2011, 09:26:04 AM »
the bike is a solo rider, but my concern is with the 12.5 shocks,
never any problems with a 205-60 GYTT
X Ring
« Reply #4 on: April 24, 2011, 09:51:38 AM »
Your shorter shocks were the reason I said to check for rubbing.  If there's not any signs you might be ok with a 65.
Marty
