February 02, 2026, 06:28:39 AM
stripped a bolt on left engine guard
Topic: stripped a bolt on left engine guard (Read 1519 times)
giff
April 24, 2011, 09:14:17 AM »
Hi to all, I was just putting on the new left engine guard and I must have overtightened the long lower bolt that has the spacer. About 3/8 of an inch at the end is stripped off[no threads]. Do you think that just buying a new bolt will fix it ? Are the threads on the frame stronger? If not ,any suggestions?
giff
GOOSE
D.S. #: 1643
Southwest Virginia
Re: stripped a bolt on left engine guard
April 24, 2011, 09:50:38 AM »
giff....i too did the same thing on mine a couple of years ago......i tried the "a little longer bolt" deal, but for me it didn't work out well. i ended up having to put a thread insert in, and that took care of my problem. i'm sure that there will be somebody else on here that will come back with a better way to solve this problem. this board really does have some talented people on it
April 24, 2011, 10:50:02 AM »
Install a Heli-Coil in the hole and your problem is gone....
Now, this time, do not over tighten.
April 24, 2011, 05:32:22 PM »
I boogered one up a little with no overtightening. The guard bar did not line up exactly with the hole, and it was a bear to try to hold it lined up and work the wrench too. Mine started straight but got a little cross threaded near the end... I just tightened it down carefully and will worry if I ever have to take it off.
I should have loosened
all
the bolts up and then tightened them up a little at a time (like valve covers).
GOOSE
D.S. #: 1643
Southwest Virginia
April 24, 2011, 06:41:42 PM »
what jess said is the only way to put them on......a little at a time.
