2qmedic
« on: April 25, 2011, 08:50:04 AM » |
Greetings, hope everyone had a joyous Easter, remembering the day with all spirtual respects and enjoying family gatherings with all the little ones.  And it never hurts to find the prize egg!!!  I did a search and have not found what I'm looking for. It has been posted before on the RPM difference between the 205-60 & 205-65 rear tire at highway speed. Does any one have the info? Thank you much,
« Reply #1 on: April 25, 2011, 09:09:17 AM » |
This is from the link below, comparing at 3000 rpm there's very little difference. RPM with 205/60 R 16's RPM with 205/65 R 16's 3000 2908 http://www.dakota-truck.net/TIRECALC/tirecalc.html
2qmedic
« Reply #2 on: April 25, 2011, 09:29:38 AM » |
This gives the tire revolutions per mile of which I have.
What I was looking for was the motor RPM difference at high way speed.
« Reply #3 on: April 25, 2011, 09:42:01 AM » |
Don't understand what you are asking if ya don't have the rear end ratio, but try this one and see if it tickles yur inerds. LOL. http://www.tacomaworld.com/forum/tirecalc.php
« Reply #4 on: April 25, 2011, 10:06:41 AM » |
What I was looking for was the motor RPM difference at high way speed. Thanks
Hey, do you suppose if you multiplied the final transmission gear ratio of .805 X the two wheel rpm's....you might get the corresponding engine rpm??? So...3,000 at the wheel = 2415 for the engine. And 2908 at the wheel = 2340 for the engine. That's 75 rpm difference at the engine for the different tire sizes. You disregard the final drive ratio because it's the same for either situation. Be interested if someone disagrees with my suggestion, which has worked for me in the past but I may have overlooked something. I don't hold my self out as the know all/end all when it comes to such things. "This gives the tire revolutions per mile of which I have."No, that's revolutions per minute...not mile.
2qmedic
« Reply #5 on: April 25, 2011, 11:03:17 AM » |
Yea, I played around with the math alittle also. I see that there is a 3% reduction in the tire revolutions per mile, I wonder if that also equals a 3% motor rpm reduction?
ie 205-60 = 3000 rpm @ 60 mph 205-65 = 2910 rpm @ 60 mph (3000 - 3% = 2910)
This would seem logical, but for some reason just doesn't seem correct. If memory serves (and sometimes it dosen't), I was thinking there was a approx 200 rpm difference between the 2 sizes at 65 mph.
« Reply #6 on: April 25, 2011, 12:24:17 PM » |
Another approach; one mile=63,360". The circumference of the 205/60 is 80.69", the circumference of the 205/65 is 83.23". So, by dividing 63,360 by each circumference, you get 785.23 revs. per mile of the 205/60 and 761.27 revs. per mile for the 205/65. Essentially a 24 revolution per mile difference between the two sizes. I wouldn't concern myself with that so much as the handling difference along with possible extra clearance issues. The engine rpm difference at speed is inconsequential so the issue boils down to personal preference on size, handling, and clearance/mounting. As I see it, it's not going to make a big difference in economy, however it will sit you just under an inch higher with the 205/65 assuming nothing else is changed.
roboto65
« Reply #8 on: April 25, 2011, 01:54:11 PM » |
Ok what I want to know is for the front what size tire to take the 5 mph over that I show do I go up in size or down. Yeah sorry for the highjack LOL
Allen Rugg VRCC #30806 1999 Illusion Blue Valkyrie Interstate 1978 Kawasaki KZ 650 project
Mildew
Live, Not Just Exist
Auburn, Ga
« Reply #9 on: April 25, 2011, 02:42:56 PM » |
The Electra glide Harleys have an 18" wheel. Thats a 20 mph difference from the 16" at 65 mph.
2qmedic
« Reply #10 on: April 25, 2011, 02:45:29 PM » |
I know it would be; -1" taller tire = 1/2" taller axle height = 1/4" taller seat height -possible clearance concerns (not likely cause I'm a light weight) -slight handling difference if any, -small motor rpm difference. But it is the Motor RPM difference that I want to get a handle on...is it going to change anything, probably not, but it's just what I want to figure out.
« Last Edit: April 25, 2011, 06:40:04 PM by 2qmedic »
« Reply #11 on: April 25, 2011, 04:45:42 PM » |
I was just giving him an RPM comparison. I think he's too hung up on the engine speed differential between the two tire sizes. It's not that big a deal and I've spent more time on the entire issue than I normally would....but it's been raining here today. My feelings....just pick a tire you like; a 205/55, /60, or a /65, just not worth the worry 'cause it ain't gonna wear the engine out any faster or save you a noticeable amount of gas. Pick one, mount it, and ride already.
2qmedic
« Reply #12 on: April 25, 2011, 06:28:23 PM » |
Yep, its an answer that I want to know - call me hung up on it or what ever??? ain't gonna make a difference in anything, I like to figure out these things and just want to know
« Last Edit: April 25, 2011, 06:34:06 PM by 2qmedic »
Bone
« Reply #13 on: April 26, 2011, 04:31:44 AM » |
If you want bigger tires, divide your old tire diameter by your new tire diameter. This tells you what your NEW RPM will be.
FOR EXAMPLE, if you want to switch from 32" tires to 35" tires, you divide 32/35 = 0.9143. So, your NEW RPM = 0.9143 times your OLD RPM.
Mildew
Auburn, Ga
« Reply #14 on: April 26, 2011, 04:49:42 AM » |
It would be nice to cruise at 2800 rpm instead of 4000.
2qmedic
« Reply #15 on: April 26, 2011, 06:07:56 AM » |
Well, I'll be running over 100 miles today before I get back to the house. I'll record what the rpm is at different speeds and come back and figure accordingly. Stay tuned, more to come...
Mildew
Auburn, Ga
« Reply #16 on: April 26, 2011, 06:41:08 AM » |
Actually my bike runs the best over 3000 rpms. I can really feel the help it's getting after 2900 or so. I think it's suposed to run just the way it is with the 60 or 55. I've known some people to run 70's. No need for an extra gear or the taller rubber. The valks 5th gear is taller than the Harleys 96 CI 6th
Rio Wil
« Reply #17 on: May 07, 2011, 09:56:11 PM » |
Unless I screwed something up, just take the number of tire revolutions per mile and multiply by 3.333 (while in 5th gear) and you will have engine rpm. Assuming you do the number of tire revolutions in one minute, it will equal rpm. A tire that turns 800 per mile will be 2666 rpm, a tire that turns 750 per mile will be 2499 rpm. The idea is the overall drive train gear ratio times the revolutions per mile (and the revolutions are done in one minute)
