February 02, 2026, 06:46:56 AM *
Author Topic: Shock bushings for progressive shocks  (Read 1626 times)
F6CTrider
Denver, Colorado
« on: April 26, 2011, 10:34:03 PM »
I just went through the rear end maintenance thing.  Replaced dampers, splines fine, new brake pads, o-rings, etc.
Found a gift from the previous owner.......I had a set of 4 new shock bushings ready to go, but found that the P.O. did not have the correct sleave in the left bottom bushing.  Much damage to the sleave that is in there.  So I had to abort and will get this all done ASAP when the parts come in.
So here are my questions:
1. Are the stock sleaves and bushings appropriate for progressive shocks?
2. How the hell do I get the old crusty ones out?  I tried changing the upper ones but gave up after an hour or so with a C-clamp.
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #1 on: April 27, 2011, 08:47:03 AM »
#1....no they are not appropriate.
#1...no they are not appropriale.  #2...spray some wd-40 (or something similar.) on them...let them sit for awhile, and that should make them easier to take out.
F6CTrider
Denver, Colorado
« Reply #2 on: April 27, 2011, 07:46:14 PM »
Thanks so much
More home work to do......
