March 23, 2026, 08:24:54 AM *
Author Topic: How do ya tell?  (Read 1783 times)
Westernbiker
Phoenix
« on: April 28, 2011, 07:19:29 AM »
So someone is selling an older bike that they say has 500 miles on it. Without taking it apart what would you look for to see if it was a 500 mile bike or is it a 100500 mile bike?
Disc brake wear?
General over all clean?
Tell me what your ideas are.
X Ring
VRCC #27389, VRCCDS #204
« Reply #1 on: April 28, 2011, 07:23:05 AM »
Check it over as best you can and see if wear on exterior pieces match the claimed mileage.  I don't know if Carfax handles motorcycles yet but that would be another clue.
Marty
« Reply #2 on: April 28, 2011, 07:23:24 AM »
Disc brake wear?
If it was a Valkyrie, I'd look down in where people put all those chrome engine covers and
where the reed valve for the smog thing is... it should look really good there.
Take off the seat (and tank? maybe just the seat is good enough) All that stuff under there should
be really clean. And behind the side covers...
Not like my bike  Wink
Bobbo
Saint Charles, MO
« Reply #3 on: April 28, 2011, 09:26:27 AM »
Like a car, you can check many of the rubber items, like footpegs.  If the footpeg rubber looks old, but with no wear, it probably has only 500 miles.  If it's worn, then probably a lot more miles.  Same with tires.  Old looking OEM tires with no visible wear, or non-OEM?  These aren't fool-proof, but it would be a reasonable indicator.
czuch
vail az
« Reply #4 on: April 28, 2011, 10:09:58 AM »
I'll second the rubber stuff. Also the steering head bearings.
 100500 would have a hang-up at center. Go side to side It should be smoothe.
NiteRiderF6
Doug n Stacy
Mississippi
« Reply #5 on: April 28, 2011, 10:16:59 AM »
Brake disc pads, also look at the disc to detect extended use.
Westernbiker
Phoenix
« Reply #6 on: April 28, 2011, 10:45:16 AM »
Good answers guys thank you and keepem coming if ya can think of any.
ArmyValker
Richland, MO
« Reply #7 on: April 28, 2011, 11:09:58 AM »
yep, a 500 mile bike should have like new brakes on it, and OEM tires (dry rotted probably) and just about everything should look brand new that's not rubber.
mario
NW Houston, TX
« Reply #8 on: April 28, 2011, 12:56:06 PM »
i had a buddy tell me to look and feel under the fenders for rust and corrosion, too.
Mario
01 Valkyrie Standard (sold)
12 Suzuki V-Strom 1000
Spirited-6
Nicholasville, Ky.
« Reply #9 on: April 28, 2011, 01:20:38 PM »
Give the GUY a LIE Detector test.  Evil Car Fax will help, maybe.  Roll Eyes
Spirited-6
Kaiser
Gainesville, FL
« Reply #10 on: April 28, 2011, 01:31:27 PM »
As stated, tires should be about shot.  But, in addition to seeing if they are dry-rotted, you can check the DOT date stamped on them.  It's a four digit number with the year and the week of the year that it was produced.  The year on the tire should be very close to the production date of the bike.
If the PO put new tires on to sell the bike, this obviously won't work.
Westernbiker
Phoenix
« Reply #11 on: April 28, 2011, 02:14:53 PM »
Yea, has new tires.
3W-lonerider
Shippensburg Pa
« Reply #12 on: April 28, 2011, 02:34:47 PM »
one sure fire way of knowing..if the bike is in a state that requires state inspections..find out where he gets it inspected and go to that shop..they will have records dating back several years..there will be no dought on the mileage. all the shop will need is owners name and month of inspection.
ArmyValker
Richland, MO
« Reply #13 on: April 28, 2011, 02:40:02 PM »
and/or you can run the VIN at the DMV if the PO is not the original owner. The mileage should be recorded at time of title transfer.
Westernbiker
Phoenix
« Reply #14 on: April 28, 2011, 02:47:15 PM »
Would the title have the milage on it now? I don't remember if they do. California plates by the way.
« Reply #15 on: April 28, 2011, 04:43:07 PM »
Another way is the bolts. They are coated so when there is much milage on them they turn a grey. They come from the factory kinda gold colored. The ones in the front cover around the oil filter and anywhere they may get dirt on them. They cant be cleaned to make look pretty again so there is no way alter there appearance. The brake levers should have no wear on them the pivots for them should be clean no running grease. Front forks should show minimal wear no pitting in the ends that bolt to the wheel. The coating should be intact. Any kind of pitting from the front cover to forks to crash bars. Windshield no pitting or scratches. Brake calipers no dust on the inside edges facing the rotor.
« Reply #16 on: April 28, 2011, 04:53:13 PM »
Just got done servicing my 99 i/s with 43000+ miles on it. Lotsa gunk and build up on the front part of the swingarm. Some of that build up is cold patch. Hope this helps. RIDE SAFE.
ArmyValker
Richland, MO
« Reply #17 on: April 29, 2011, 04:46:55 AM »
Mine has a space for "mileage at time of transfer" but Missouri doesn't record that block, as all my titles are blank in that space.
