May 02, 2026, 05:07:56 PM *
Author Topic: E C T .Mod  (Read 1513 times)
Blade
bedford TX.
« on: April 29, 2011, 05:52:42 AM »
Hi guys
I thought I would drop in to say hi. I had back surgery two weeks ago and am in therapy now Cheesy.
I had two bulging disk, they went in and trim the bone away from the nerves.
  I was wondering if anybody out there had done the EC T. modification. I'm thinking about doing the electronic modification to try to increase the midrange power and mileage. I'd like to talk to someone that has done the modification before, just to see exactly what they thought about it. I should be able to get back on the bike in about four weeks and am looking forward to riding again.
« Last Edit: April 29, 2011, 05:55:25 AM by Blade » Logged
LIVE FREE & RIDE HARD
designer
Columbus, Ohio
« Reply #1 on: April 29, 2011, 05:59:36 AM »
I just finished mine, but I would be interested in other members experience with how it made a difference.  I added the pot for adjustment, but haven't turned it on since I got it going.  I purchased the buy used and need to look a the trigger wheel to see if its stock before I start messing with it.  It seems to be a cold natured fat lady so I am wondering if they didn't swap out the trigger wheel already.  I'll be keeping an eye on your string.
2002 Valkyrie Std
K&N Filter, Audiovox Cruise, I/S bags and trunk, Cee Bailey shield +2, ECT mod, radiator pods, driving lights, rattlebars kick shifter ,I/S ICM
5_19
Dublin, Texas
« Reply #2 on: April 30, 2011, 09:47:42 AM »
I did it on my bike when i first got it, only because it seemed like a good thing (translate   Evil couldn't hurt anything) to do and it was cheap enough. After 40K miles I don't think it makes any difference. When we where at the RLAP in Houston on April 2 I had to turn it off because without it the bike is easier to control at slow speed. There was a reason Honda made it stop after the engine warms up. I also found that my bike runs not as lean when it's turned on at 50 mph. Every bike seems to run slightly different and you may have better results.
My conclusion and personal opinion: I shouldn't have done it. Valkyrie that have a lean spot at rpm below 3000 may seem to benefit from it, but why not fix the lean spot and get better response, hp torque etc and mpg if you can keep from twisting that throttle.  Shocked Cool Grin Grin
IBA # 45723
2009 BMW R1200 GSA
Blade
bedford TX.
« Reply #3 on: May 01, 2011, 07:01:19 AM »
Thank you! this is what I was looking for !!!I will save myself some work !I am OK with the bike the way it is, but always wan't more MPG .But not at the risk screwing something up .  cooldude
  Now if I can just hold out a few more weeks I sould be back on the bike .
