February 02, 2026, 10:00:54 AM
Got a miss
Topic: Got a miss (Read 1677 times)
valkyalky
Got a miss
April 29, 2011, 07:29:35 AM »
My 99 tourer has been experiencing a miss on what feels like 1cylinder ever
Since I got it back from the paint shop. I did run it out of gas prior to pulling the tank. It seems to idle fine only missing when I accelerateand then on hard throttle it smooths out . Any ideas? Also I just discovered that my eBay exhaust is really messed up. I pulled the tips off and discovered that the entire rear "plate" where the piggies would come through is missing. Just a big hole with the 3 divider plates showing. Is this a re jetting situation? I love the sound.
Re: Got a miss
April 29, 2011, 08:02:41 AM »
Probably the first thing to do is a compression test to be certain the motor is not the problem.
Re-jetting is not always called for with changes made to the exhaust system.
Might be a good idea to run some additive through the fuel system for a start!
GOOSE
D.S. #: 1643
Southwest Virginia
Re: Got a miss
April 29, 2011, 08:25:45 AM »
on one of my valk's i have the ragnor cut done....on mine (i'm sure other valk's are different.), i had to pull carbs, and re-jet because the dang thing was running too lean.
Momz
ABATE, AMA, & MRF rep.
Re: Got a miss
April 29, 2011, 10:52:01 AM »
I used to have a miss,....but then I married her.
ALWAYS QUESTION AUTHORITY!
