February 02, 2026, 08:22:40 AM *
Author Topic: My Valkyrie build adventure....  (Read 2440 times)
Dennis316
« on: May 01, 2011, 02:47:58 PM »
So i was roaming around craigslist in the seattle area when i noticed a guy was selling a 98 valkyrie for 1800, i know what these bikes are worth and could use a project. I just recently got married and sold my sport bike. I wasnt really in the market for a cruiser, i just happen to see this beast and picked it up. It was complete except for the exhaust pipes. Hasnt run since 2003 according to the previous owner. He took it apart to re chrome everything because he lived near the ocean and never ever washed the bike. parts of the chrome were flaking off here and there, overall it wasnt bad. So i took it home and opened up the gas tank and the tank has about 1mm of rust EVERYWHERE.
I used good ole electrolysis to get all that rust out and ordered some Bill Hirsch (sp?) tank sealer and cleaner, as it is not affected by ethanol...wow that stuff is amazing! their tank prep was awesome too, and cheap!
anyways, i got the tank sealed, and the old petcock was messed up 2 ways from sunday. Went to pingel after some research and bought me one.
after that i decided i wanted to start it and see it the monster 6 would fire up after 8 years of sitting. i got a new battery and hooked up all the buttons and switches required for the sensors to let the engine turn over. all the cables were stuck so i lubed those up too til they worked good as new. turned the engine over and it fired up within 3 seconds (good ole honda engineering!). ran for a few seconds and shut down. at this point i am more excited than a man on his honeymoon.
i lengthened the fuel hose and put the tank on. the previous owner said he drained the bowls as best as he could so i decided to try without cleaning the carbs (yeah it was a LONG shot). realized only 3 of the cylinders were firing and decided it was time to take off the carbs. The carb setup looks mighty intimidating if you ask me so the first thing i did was call a shop and ask how much they charge. the guy was nice and said they do valks all the time. said he would do it and a complete carb rebuild for 600 bucks.
i personally would like to keep the 600 bucks in my pocket and decided to go for it myself. after taking 100 pictures i realized that the carbs only hook up in a few places and it actually wasnt that bad...the float drain tubes go on the bottom of the carbs and from there its pretty easy if you ask me...took me less than a day to take them off and put them all back on after cleaning.
checked all my hose connections and put on the tank and turned her over on choke. Ran like crap for a while and wouldnt rev past 3k for a minute or two. i let her idle and it started getting better and better. I decided to get some premium fuel and mix it with carb cleaner to clean the carbs a bit better. went to the gas station and got the fuel and came back. at this point the whole bike is almost put together, i was going to take it for a ride in about 10 minutes!
put in the new gas, turned on the fuel, and heard a SNAP...
took off the starter, all the while PRAYING the starter broke and nothing inside....no such luck for me apparently because the starter idle gear stripped 2 teeth from hydrolock...when i left to the gas station i forgot to turn off the fuel. found out cylinder 5 flooded, most likely from a stuck float and now the engine is almost out of the valk...few more days and ill have her running...AGAIN!!!  uglystupid2 cant wait to be on it and riding...it sounds soooo good and inviting when it ran for those few minutes!
atleast i know it runs now! are there any issues i can run into replacing the idler gear?
5_19
Dublin, Texas
« Reply #1 on: May 01, 2011, 02:53:07 PM »
Welcome to the Inzane world of Valkyries!  Evil Evil
IBA # 45723
2009 BMW R1200 GSA
Mr.BubblesVRCCDS0008
« Reply #2 on: May 01, 2011, 04:31:48 PM »
Welcome to the world of the bigg flat six. I'm glad to see you have the abilty to wrench on your own bike.
« Reply #3 on: May 01, 2011, 06:45:35 PM »
Welcome to the insanity. It's a good kind though-once in awhile anyway.  uglystupid2 You get your new to you fat girl runnin right-well i ain't the only convert on this board. Ya got it fer a good price. Little bit a wrenchin and your crusin large. RIDE SAFE.
X Ring
VRCC #27389, VRCCDS #204
« Reply #4 on: May 01, 2011, 06:51:36 PM »
You can add a Dan-Marc electric fuel valve between the Pingel and the tee for the carb banks.  That way you don't have to worry about forgetting to turn the Pingel off.
Marty
« Reply #5 on: May 02, 2011, 07:08:33 AM »
If we're talking about the same gear you might find that the shaft the gear rides on sometimes breaks the boss that it pilots in.
I think you'll find it if that has happened since you have to remove that part of the motor case to replace the idler gear.
Redline +
Northwest Washington
« Reply #6 on: May 02, 2011, 10:25:29 AM »
So i was roaming around craigslist in the seattle area...
If you're in the Seattle area, and would like to ride with other Valks, check out the Vermin Club. We are the Washington State Chapter of the VRCC. We meet once a month, second Saturday.
www.vermin-club.org
Redline  Cool
Chiefy
Sarasota, Florida
« Reply #7 on: May 02, 2011, 02:32:09 PM »
Ouch, sorry to hear about the hydrolock.  What a welcome to the world of Valkyries.
