February 02, 2026, 08:35:19 AM *
Author Topic: Battey Voltage  (Read 1954 times)
shortleg
maryland
« on: May 02, 2011, 05:30:25 PM »
 I just replaced my battery.
New battery has 13.4 volts,what volts
should it read when running?
        Shortleg[Dave]
BigMac (SoCal)
Moreno Valley, California
« Reply #1 on: May 02, 2011, 05:34:31 PM »
Should be around 14.2 volts while running.
Dave
shortleg
maryland
« Reply #2 on: May 03, 2011, 03:50:35 AM »
  Thanks, will put my VOM on it while it is running
at above 1000 rpm to check charging.
         Shortleg[Dave]
Dirty Dave
Montreal, Canada
« Reply #3 on: May 03, 2011, 04:11:17 AM »
My Valk won't charge at 1000 RPM. It got to be above 2500.
It's weird being the same age as old people
valkyriemc
NE Florida
« Reply #4 on: May 03, 2011, 04:48:43 AM »
If your reading 14.2 VDC that diff in potential would seem to indicate some current would flow. The guy who rebuilds Valk alternators (ken ?) could probably say for sure.
If you follow this link you can see a graph from a compu fire
alternator vs. a (Goldwing) stock unit; http://www.compufire.com/honda-main.html
« Last Edit: May 03, 2011, 04:53:05 AM by valkyriemc » Logged
Veteran USN '70-'76
DFragn
« Reply #5 on: May 03, 2011, 04:54:53 AM »
At idle [900 rpm] and with over 200 watts of accessories running my alternator [OEM @ 85k New brushes @ 60k] is still putting out 14 volts. At 1500 rpm it's doing 14.2. When I park it the battery is at 13.2+, so it is charging.
However, at 2 weeks of not riding it won't start. This is due to the memory drain of the car stereo, CB memory and the alarm. So, if it sits for a week I put the Tender on it.
sugerbear
wentzville mo
« Reply #6 on: May 06, 2011, 05:45:01 PM »
if it's a stock alt. i think you have a problem......................
