February 02, 2026, 08:40:12 AM *
Author Topic: clunking noise left side of tourer  (Read 1998 times)
mudausasix
« on: May 03, 2011, 03:28:49 PM »
I was slowing down yesterday heardda clunking sound on the left side of my fat lady tourer shifter works fine clutch works fine i think its comming from the rear any ideas on what it could be going to remove saddle bags check all bolts and pads back there any suggestions please help next step is to take to stealer for diag
« Reply #1 on: May 03, 2011, 03:33:21 PM »
Sounds like another left rear wheel bearing.
« Reply #2 on: May 03, 2011, 05:22:29 PM »
See if there is any play (looseness) in the rear wheel.
Side to side, angular, whatever.  Might take some muscle!
sugerbear
wentzville mo
« Reply #3 on: May 04, 2011, 01:02:46 AM »
tell us where your located. maybe someone close can help diagnose it, without going to the stealer.
we're much cheaper cooldude
stude31
Topeka,ks
« Reply #4 on: May 04, 2011, 08:02:25 AM »
lil bull had this same issue.....
I rode his bike and could feel the vibration in the driver pegs.  I noticed it was worse on "rear braking".  I rolled to about 15mph and put the bike in neutral (accelerate in first gear then shift to neutral, don't get the bike going too fast you can cause stress to the tranny "forcing" it into neutral).   You just want to be rolling down the road in neutral and then once you do this apply the rear brake.  If vibration worsens then you your chances of it being a wheel bearing is my suggestion.  The honda shop showed me his wheel as they pulled the axle out and the balls were falling out of the wheel....
Ricky-D, as we have discussed before regarding a wheel bearing failure is problem matic on the left rear but you and I don't agree and that's okay... to each his own..   Wink
« Reply #5 on: May 04, 2011, 02:18:02 PM »
Studly, the noise I had the other day, went bye bye on the way home after just a couple miles, I jacked it up and checked for play when I got home, I still want to do the double row mod one of these days.  Hoser  Cheesy
« Reply #6 on: May 04, 2011, 03:23:16 PM »
Does it get amplified when you put on the rear brakes?
Does it sound kinda like this?...............
http://youtu.be/12E1chD1e4c
Or this?...............
It's your left-rear wheel bearing.  Replace both the left and the right.  Not too expensive.....even if you have someone else do it.
« Last Edit: May 04, 2011, 03:24:59 PM by BF » Logged
