May 02, 2026, 05:07:00 PM *
Author Topic: HELP: Need new Rear Brake Caliper  (Read 1771 times)
DrewDanube
Houston, Tx
« on: May 04, 2011, 04:14:14 PM »
Hey all...LONG time, no post.  Been too busy working (and riding).
We had to pull the rear wheel to re-pack the splines and in the process managed to permanently get the pin that holds the rear brake pads to the caliper affixed to the caliper itself.  We're twisting off allen wrench ends!
New Caliper time...
however, it appears the entire sub-assembly and a best price thus far of 297 is a bit...high.  Any suggestions on where to go or even better does anyone have a used one I could buy?
Andrew
And into the great beyond I go...
previous bikes:
Suzuki Intruder 1400
KLR650
V-Max
FZ-6
Bandit 1200S
Hyosung Avitar GV0650 (sold!)
Valker
Wahoo!!!!
Texas Panhandle
« Reply #1 on: May 04, 2011, 04:25:22 PM »
There's usually some on eBay, but you might take it to a machine shop to have them remove it.
DrewDanube
Houston, Tx
« Reply #2 on: May 04, 2011, 04:38:24 PM »
Is a caliper a caliper?
In other words, would a caliper off a 1997 Valkyrie tourer just pop right on?
previous bikes:
KLR650
V-Max
FZ-6
Bandit 1200S
wizard -vrccds#125
Hitchcock Tx.
« Reply #3 on: May 04, 2011, 07:44:14 PM »
I have a couple in the barn. Just give me a holler an we will work it out ! No problem  uglystupid2
Rocketman
Seabrook, Texas
« Reply #4 on: May 05, 2011, 10:10:02 AM »
Duane, you know what you need?  More supervisors.
Rocketman
Seabrook, Texas
« Reply #5 on: May 05, 2011, 10:11:44 AM »
I believe so.  I recommend you do a fiche comparison.  Check part numbers.
« Reply #6 on: May 05, 2011, 01:09:48 PM »
 * is a caliper a caliper...
Interstate calipers are different from STD/Tourer calipers... they have smaller pistons...
Calipers are only about $25 dollars from Pinwall... they're usually perfect after you
clean them up and replace the rubber...
Tinman
Manvel Tx
« Reply #7 on: May 05, 2011, 01:10:09 PM »
It is my understanding that one from a 97 will NOT fit a 99 to 2001 interstate.
There were some deign changes made.
I would get a parts guy to verify before bought one from ebay or elsewhere.
And then make sure the seller REALLY knows what it is off of.
That is my .02 and I'm sticking to it!
Tx Bohemian
Victoria, Tx
« Reply #8 on: May 09, 2011, 06:12:06 AM »
I put a rear wheel (w/rotor) off of a '98 standard on my '99 standard and had to shim the rotor out to get it to center in the caliper and not rub.  Some suggested here the rotors are different.  The bike the wheel came off of was rear-ended way back when it was new so it's no telling if it was put together with the correct year/model parts when it was rebuilt.
Point being: there are some differences in the rear brake components. Not sure if the calipers themselves are different though, but you're in the right spot for the answers.
Al
DrewDanube
Houston, Tx
« Reply #9 on: May 09, 2011, 06:41:25 AM »
How about a caliper from a 2000 C/CT model on a 2000 IS?  Is it the same caliper, just different color?
previous bikes:
KLR650
V-Max
FZ-6
Bandit 1200S
« Reply #10 on: May 09, 2011, 07:51:56 AM »
I'm guessing that all Interstate rear calipers are different from all STD/Tourer calipers... they don't
seem all that different when you're holding each in your hand, but by the time you tear them down and
you got one of each piston in your hand... they seem real different...  Smiley
Pinwall lists the specific type of bike each part came from... I've gotten numerous front and rear
calipers from Pinwall, never cared what year, just Tourer or Interstate... they've always been
just right.
DrewDanube
Houston, Tx
« Reply #11 on: May 09, 2011, 09:37:46 AM »
Went ahead and ordered a 99 I/S caliper from Pinwalls.  Seem like good folks.  50 bucks w/ 2 day air is ALOT more palatable than a new one!
previous bikes:
KLR650
V-Max
FZ-6
Bandit 1200S
