February 02, 2026, 08:40:11 AM *
Author Topic: 5" truck stacks  (Read 1748 times)
deadvelvet
Owensboro,KY
« on: May 04, 2011, 04:58:48 PM »
how do you get rid of the big gap when you put on 5" truck stacks
DFragn
« Reply #1 on: May 04, 2011, 05:15:06 PM »
Maybe with Silly Putty [Silicone].
Just kidding.
Maybe you could float with spacers, tabs & spot tacking clamps to the OEM header to muffler cover out a half inch.
A little ingenuity, which I have none of, would help.
EDIT: I fergot the circumference of the OE cover won't match up well. Maybe it's possible to open up the can end a bit without fracturing or flaking the chrome.
« Last Edit: May 04, 2011, 08:19:54 PM by DFragn » Logged
Bone
« Reply #2 on: May 05, 2011, 04:44:31 AM »
Seems like they used a bell type reducer. At the top of the page you will see "Old Tech Archive".
Click on that and there will be a search bar. Type in  "Truck Stacks " and you will get a ton of reading from past posts.
« Reply #3 on: May 05, 2011, 05:53:40 AM »
Hey long time no post!
Search or check with EEZZZRIDER from up my way. He has 5" ers on his and had some kinda reducer. Not sure if it was made or a oem part. Might check with a big rig place.
