September 16, 2025, 01:00:51 AM *
Author Topic: Cookie time...  (Read 1143 times)
PhredValk
Edmonton, Alberta, Canada
« on: May 07, 2011, 07:37:16 PM »
Well, it took some doing, but it fits.
Falken Ziex ZE-512 205/65R-16. I haven't ridden it yet, but there it is.
Fred.
VRCCDS0237
wdvalk
Katy Texas
« Reply #1 on: May 07, 2011, 08:28:02 PM »
got the same one
SANDMAN5
Mileage 65875
East TN
« Reply #2 on: May 08, 2011, 08:43:50 AM »
Let us know how much your rpm drops on the hwy.
X Ring
VRCC #27389, VRCCDS #204
« Reply #3 on: May 08, 2011, 09:11:43 AM »
I've got the same size on my Tourer.  My rpms dropped by a couple hundred revs.
Marty
Fudd
MSF RiderCoach
Denham Springs, La.
« Reply #4 on: May 08, 2011, 09:35:28 AM »
I'm just curious.  Did you remove the back half of the fender to do the nut cage mod or was there another reason?
Save a horse, ride a Valkyrie
PhredValk
« Reply #5 on: May 08, 2011, 09:49:47 AM »
I removed the fender to do the nut cage mod, and to install the Electrical Connections run/brake light package into the signal pods (which will have to wait because I can't find the darn things).
Seeing that I had to remove the saddlebag supports to get at the shock bolts and caliper stop bolt (much easier than dropping the exhaust, which I didn't even have to loosen this way) and there's no way I would have gotten the tire under it, I will remove it for every tire change or spline lube.
Fred.
VRCCDS0237
Fudd
MSF RiderCoach
Denham Springs, La.
« Reply #6 on: May 08, 2011, 10:43:56 AM »
The electrical connections turn signal mod was the first change I made on mine.  I love the idea of keeping my amber turn signals intergrated with red running and brake lights.  Much more noticable than the "Hog style" red blinkers.  I think they are great.
On youtube, Dagg1520 shows an easy way to slip the wheel out without removing the exaust or rear fender half.
By the way, did you get your cookies or DS# ?
RTaz
Oscoda, Michigan
« Reply #7 on: May 08, 2011, 05:55:50 PM »
 Smiley now try cleaning those pipes while their expose...lol.... cooldude
 RTaz
PhredValk
« Reply #8 on: May 08, 2011, 08:21:09 PM »
Cleaned the chrome after getting things tightened and torqued (how the heck do you get a torque wrench on the back 2 drive bolts?). Waiting for the bags at the painters and have to do the front tire and fork seals. Hope soon, or it will be winter again...
Fred.
VRCCDS0237
alph
Eau Claire, WI.
« Reply #9 on: May 08, 2011, 08:28:35 PM »
seen that video!  it's the only way to remove a tire!!  i use to remove the fricken exhaust pipes before i saw that video, one time the mounting bolts broke off and i had to weld on new ones, won't ever have to do that again!!
