July 19, 2025, 07:58:00 AM *
Author Topic: Crisis averted. Almost burned the Valk up!  (Read 844 times)
Titan
BikeLess
Lexington, SC
« on: May 08, 2011, 02:54:02 PM »
A couple of years ago I wired an auxiliary power plug into the saddlebag for using a phone charger, etc. It's been just fine for two years. Today I was getting ready to ride a bit, reached into the bag, moved the cord, and sparks flew and it started smoking! Panic mode! I grabbed the wires and snatched them out hoping it would stop. Smoke started coming from under the seat and my brain just kind of stopped working for a second! crazy2  It was the weirdest thing... smoke was settling downward on the garage floor instead of rising. I finally got the seat off and pulled the rest of the wires loose that I had installed for the accessory.
Fortunately, the only damage incurred was the pair of wires that I installed. That I personally installed... with NO FUSE! uglystupid2 No Fuse! What the hell was I thinking? I've been wiring stuff up for 50 some odd years and have never installed anything without a fuse! I can't imagine where my head was but I hooked a pair of 18 ga automotive wire directly to the battery and ran it back into the leather saddlebag with a cigarette lighter plug on the end to plug chargers into. NO FUSE!
I'm mighty lucky that it never lit up before and that I stopped the fire before it hurt anything else.
But now I'm aware of just how really stupid I am... or can be. crazy2
Gear Jammer
Yeah,,,,,It's a HEMI
Magnolia, Texas
« Reply #1 on: May 08, 2011, 03:07:22 PM »
You work on something long enough, and you're going to eventually do something "unsmart". crazy2
art
Grants Pass,Or
Grants Pass,Or
« Reply #2 on: May 08, 2011, 03:50:34 PM »
NO FUSE? You were very lucky.The wire harness is very expensive .I had my harness burn up while still on warantee an hond replaced it I was also lucky.
hotglue #43
« Reply #3 on: May 08, 2011, 07:21:18 PM »
fuses are your friend!!!!!!
 blue=3 times
 green=at least 4 times
