May 02, 2026, 02:35:23 PM *
Author Topic: Cooling question  (Read 3930 times)
Houdini
VRCC #28458 - VRCCDS#144
Allen, TX
« on: May 10, 2011, 07:13:45 PM »
OK, I have something strange going on with my Valk.  She keeps running hot and when I check the coolant level she is low in the radiator but OK in the reservoir.  This has been going on for about two weeks now.  I noticed she was hot riding home from work today so I checked the coolant levels again and the radiator was almost empty but the reservoir was almost full.  I've already changed the cap.  The one I had seemed fine but the rubber was looking a little rough so I went ahead and changed it out with a new Honda cap.  It appears that I have about a 60 - 90 mile range now before heat starts becoming an issue.  Any ideas?
Valkpilot
What does the data say?
Corinth, Texas
« Reply #1 on: May 10, 2011, 07:56:43 PM »
Is the cap tightening down correctly?  Seems like I recall that the retaining tabs can get bent so that they don't lever the cap down properly when you screw it on.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Houdini
Allen, TX
« Reply #2 on: May 10, 2011, 08:01:23 PM »
It screws down tightly with no wiggle after tightened.  I'm wondering if maybe it has a weak spring.
Six Guns
Fort Worth, Texas
« Reply #3 on: May 11, 2011, 07:07:59 AM »
Chuck,
  Was this happening before you changed the cap or since you changed the cap? Just trying to figure out if the new cap has anything to do with your problem.
Disco
Republic of Texas
« Reply #4 on: May 11, 2011, 07:09:44 AM »
You might check the siphon hose for good connections on both ends and no cracks or leaks.
22 CRF450RL, 19 BMW R1250RT
78 CB550K, 07 Helix
71 MT50 Trailhopper
Wanderer
The Great Republic of Texas - Dallas
« Reply #5 on: May 11, 2011, 07:16:29 AM »
Be sure you let her burp or belch when you add the new antifreeze. Leave about an inch of fill space rather than topping her off to avoid overflow when she does belch. Once she belches and the antifreeze is circulating shut her down and top her off. Put the cap on. Otherwise she will air lock and cause just the kind of problem you seem to be having, Chuck. Might check the tubing between the overflow and the radiator for obstructions while you are at it just to be sure. ~Jeff
More Valk Pics...
had a couple of Valks once upon a time
2004 DRZ400S
2005 GS1200
1978 CB550K
1977 CB550F
Houdini
Allen, TX
« Reply #6 on: May 11, 2011, 03:35:36 PM »
I checked my reservoir one day and it was empty so I checked my coolant level and it was a little low, I inspected the cap and it looked like it should be changed, so I did.  I have been having coolant issues ever since.  It may be from the cap or I may have caught the problem just as it was starting.
It looks good on the ends that are easy to see and the coolant is readily making it from the radiator to the reservoir.  Unless a gremlin stuck a check valve in the middle where it is hard to see I think it is OK.   Cheesy
I'll give that a try after dinner
See smart @$$ comment left for Disco  Evil
RainMaker
Arlington, TX
« Reply #7 on: May 11, 2011, 04:07:04 PM »
I more thought, although I hope not the case.
Have you checked the oil?  Is it high or kinda' milky in appearance?  As in head gasket issues?
That would drain the radiator and cause the motor to overheat as well.
Again, hope that is not the case.
RM
2005 BMW R1200 GS
2000 Valkyrie Interstate
1981 GL1100I GoldWing
1972 CB500K1
Houdini
Allen, TX
« Reply #8 on: May 11, 2011, 05:49:27 PM »
The oil looks good, probably due for a change but no water in it.
I let it run with the cap off to 'burp' it like Jeff suggested.  The coolant began to overflow the radiator within a few seconds and it dumped quite a bit of coolant on the ground.  It eventually burped, the coolant level went down then began to flow.  After about 30 seconds it quite flowing and began to rise and overflow the radiator again.  Even though the bike was up to temp the coolant didn't rapidly flow any more and it began to dump on the ground.  When I shut it off the coolant level dropped by about 5 inches.  I'm beginning to think my thermostat may be bad and she really is just plain ol' overheating.
5_19
Dublin, Texas
« Reply #9 on: May 11, 2011, 06:00:11 PM »
Chuck, start the bike cold with the fluid level in the reservoir at the minimum level. After it warms up the level in the reservoir will be at or above the max line and this is normal. I you do this with the bike parked you will find where you are loosing coolant, it could be as simple as the syphon tube connection or the cap. I had a crack on my reservoir where the tube connects and never had a leak on the floor.
IBA # 45723
2009 BMW R1200 GSA
Hoghead
Kilgore, TX
« Reply #10 on: May 12, 2011, 08:10:31 AM »
You may be on to something with the check valve theory. It sure seems cap related to me. With pressure it lets water out and a suction lets it back in as temps lower. The cap may not be letting it back in. Try another cap. I know this is a long shot but i have had the overflow hose that was too long and it stuck to the bottom of the reservoir tank and created a check valve effect.
by the way if you don't get it fixed by the wrench party you can ride it a few miles and let it cool and ride a few more. You should be here for some leftover BBQ.  2funny
2000 I/S. Coronado Blue & Silver
1984 V65 Magna. Really Fast Black
E. Texas Patriot Guard Rider
Houdini
Allen, TX
« Reply #11 on: May 12, 2011, 09:40:30 AM »
Try another cap
There lies the problem, Honda wants $35 for a radiator cap.  That's a lot of money to 'try another cap'.  Unfortunately I threw the old one away 'cause I didn't think I'd need an old cap.
« Reply #12 on: May 12, 2011, 10:05:29 AM »
Wanna borrow mine? You're welcome to swing down to Rowlett and borrow it for a day or two just to check... Mine's stock (Chrome doodad stuck over OEM cap), and original to the bike...
roboto65
Conroe,TX
« Reply #13 on: May 12, 2011, 12:26:45 PM »
No need to spend the money on Hondas cap here is a link to a replacement.
http://www.autozone.com/autozone/parts/1994-Honda-Accord-DX/Radiator-Cap/_/N-j0zkhZ9pd9v
Allen Rugg
VRCC #30806
1978 Kawasaki KZ 650 project
RainMaker
Arlington, TX
« Reply #14 on: May 12, 2011, 03:24:54 PM »
I'll bring mine to the meeting tonight if you want to use it for a couple of weeks.  I won't be needing it!
Mark
2005 BMW R1200 GS
1972 CB500K1
Westsider
Fort Worth TX.
« Reply #15 on: May 16, 2011, 02:16:29 PM »
hopefully the radiator is just getting a "little low" if its "almost empty" thats a lot of coolant and its either getting all over your bike somewhere or your burning it..hopefully the earlier,holds 4 qts. right?
Houdini
Allen, TX
« Reply #16 on: May 16, 2011, 03:09:59 PM »
It appears that it was a poorly fitting cap.  I bent the tabs down slightly making the cap difficult to put on but it has been working correctly since last Thursday when I bent them.  Thanks for the suggestion VP.
You'd think a $35 dollar radiator cap would fit correctly the first time.
Valkpilot
Corinth, Texas
« Reply #17 on: May 16, 2011, 07:51:39 PM »
Out of the junkyard of my mind comes an occasional nugget...
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
« Reply #18 on: May 17, 2011, 08:16:58 AM »
Keep them nuggets comin' VP!
Hay Cool
