January 28, 2026, 12:36:55 PM *
Author Topic: '97 Standard Header Bolts  (Read 4396 times)
Bonzo
« on: April 16, 2009, 06:22:53 PM »
Seem to have lost two of the acorn bolts that hold the exhaust on . Does anyone know the size? #15 on the exhaust microthing
Woops, I'm sorry.
Six Guns
Fort Worth, Texas
« Reply #1 on: April 16, 2009, 06:44:39 PM »
From what I can see it's a (6MM Nut Cap). # 16
http://www.hdlparts.com/fiche_section_detail.asp?section=148044&category=Motorcycles&make=Honda&year=1997&fveh=3465
Bonzo
« Reply #2 on: April 16, 2009, 10:24:48 PM »
Thanks! better microfiche than the one on tech tips, this one gives the aprt! different # also.
Woops, I'm sorry.
« Reply #3 on: April 17, 2009, 08:33:22 AM »
They're unusually long (deep?) and cost about a million dollars apiece from Honda.
I don't know of an alternative.
PharmBoy
Lawton, Ok
« Reply #4 on: April 18, 2009, 07:53:50 AM »
I took all my remaining OEM exhaust nuts off and gave them away.  Bought one star washer and 2 stainless nuts for each stud.  Put on the star washer against the exhaust flange and one SS nut behind that.  Torque the first nut to 7 ft/lbs (84 in/lbs), then use an open end wrench to hold that torque value while tightening the lock nut.  Run it a while and re-torque using the same procedure.  Double nutting has long been a recognized procedure for keeping things in place.  Have lost no exhaust nuts and no exhaust leeks after using the lock nut procedure...JTL   cooldude
4th Infantry Tet Vet
99 Interstate
97 Bumble Bee
97 Red & White
Michael K (Az.)
Glendale, AZ
« Reply #5 on: April 18, 2009, 03:36:44 PM »
That sounds like a good idea, Pharm boy. Big BF and I did a pretty exhaustive (no pun intended) search in the Phoenix area for any after market studs and heads to no avail! Just the qurillion $$ Honda ones. Double nutting sounds like the solution to me!
Bonzo
« Reply #6 on: April 20, 2009, 07:16:57 AM »
Double nutted it is!
Woops, I'm sorry.
