February 02, 2026, 10:18:33 AM *
Author Topic: Gas Smell  (Read 2224 times)
DavRed
Buckeye AZ
Phoenix AZ
« on: May 13, 2011, 12:09:27 PM »
I don't seem to be able to find it.
I have checked for vacuum  leaks. I spreyed starter fluid all around the hoses and carbs while the Valk was running hoping to find a vacuum leak. No dice. I checked the petcock. Does not seem to be a leak there. Dry both after riding and sitting.
The smell seems to be coming from the left carburetor bank. That is where it is the strongest. But I don't see anything there.
Any other ideas would be great.
2000 Interstate if that makes any difference.
roboto65
Conroe,TX
« Reply #1 on: May 13, 2011, 01:59:17 PM »
Well gas vapors sink as they are heavier than air it may be coming from your gaskcap this happens and there was a post about this the other day. They do not sell the gasket seperate either LOL someone mentioned vasoline on the rubber to refresh it.
Allen Rugg
VRCC #30806
1978 Kawasaki KZ 650 project
Baloo
Rimouski, Canada
« Reply #2 on: May 13, 2011, 03:26:56 PM »
I experienced a gas smell on mine last year. As suggested by someone here, I removed the rubber seal from the tank cap and put a piece of thin carboard under it as a shim. The cap closes tighter now and the smell is gone cooldude
Never ride any faster than your guardian angel can fly...
DavRed
Buckeye AZ
Phoenix AZ
« Reply #3 on: May 13, 2011, 04:52:44 PM »
I will give the gasket a shot. I already coated it with Vaseline. That didn't make a differance in the smell.
Thanks for your help....
rodeo1
« Reply #4 on: May 13, 2011, 04:58:22 PM »
i think they just burn so much gas that you can't help but to smell it. Grin
glassguy
« Reply #5 on: May 13, 2011, 05:21:09 PM »
Replace the intake o-rings.  Solved the problem for me
Red Diamond
Beaumont, Texas
« Reply #6 on: May 13, 2011, 05:31:42 PM »
There is a very good Honda mechanic in this area of Texas that I know and use sometimes. When I told him about the gas smell, when I purchased my I/S 5 years ago, he told me in no uncertain terms,
"That's Six Carberators You're Sitting On Top of". That's when I came to this board to get an answer.
DavRed
Buckeye AZ
Phoenix AZ
« Reply #7 on: May 13, 2011, 06:49:54 PM »
AND the answer was? I have had this bike for 40K and the smell just started . Got to be something new. I wil try the gasket thing. I know that covering the gas cap area with electric tape did not work....
Thanks for all the help
« Reply #8 on: May 15, 2011, 06:23:26 AM »
Cut a piece of inner tube to the same size as the existing gas cap gasket and add it on top.
