February 02, 2026, 10:19:10 AM *
Author Topic: Repairng a Hydrolocked Valk and need to know the socket size for the output shaf  (Read 1618 times)
dalai-lama
Wish I was out riding...
Watertown CT
« on: May 15, 2011, 02:21:39 PM »
The manual says 30mm x 64mm and 30mm is way to small.  Got a welder and welded up the socket for the clutch basket but now need to build a tool for the output shaft.
Just need to get this nut off and then I can pull the bolts and separate the rear cover and see exactly what is broken,  I can see the case snapped where the pin holds one gear in and also one gear is missing some teeth but I think most of the rest will be okay.
Any help will be greatly appreciated.
the dalai
the dalai
dalai-lama
Watertown CT
« Reply #1 on: May 15, 2011, 03:30:35 PM »
Okay, a little search the history and found it is a 36mm.  Off to find one of those tomorrow and get the rear cover off and see what we have  cooldude
the dalai
the dalai
