February 02, 2026, 11:38:37 AM *
Author Topic: Is it likely that putting a coverset in my petcock could improve the way  (Read 2036 times)
Quicksilver
Norway Bay, Quebec, Canada
« on: May 18, 2011, 03:18:41 PM »
my Valkyrie runs or is it my imagination that she runs smoother?
This diaphram does look worn but I'm not sure that the ring around the central pin is normal or not.
Any comments?
1997  Standard
« Reply #1 on: May 18, 2011, 04:47:03 PM »
its worn leaking vacuum restricting fuel flow. I had same problem, bike ran uneven showing signs of leaness. it even acted like it was running out of fuel. mine looked like that after 15k miles.
search my posts for repair part #s and about putting a snubber in the vacuum line which should extend its life.
Quicksilver
« Reply #2 on: May 19, 2011, 04:03:39 AM »
Thanks CA, I did put a coverset in, and it does seem to run smoother. I find that when I twist the wick now it doesn't have that brief hesitation that it did.  cooldude
1997  Standard
csj
Peterborough Ontario Canada
« Reply #3 on: May 19, 2011, 06:07:11 AM »
Oh wow, a diaphram can make your valk run poorly?
That would explain my bike feeling like it has less power.
Can you tell me where you ordered the coverset from, dann.
Gonna do the upgrade.
Quicksilver
« Reply #4 on: May 19, 2011, 06:11:22 AM »
Powersport Honda in Ottawa, the local dealer, not that pricey, 2 day delivery. I pulled the tank but didn't remove the entire petcock from the tank, just unscrewed the 4 screws from the petcock and put the new parts in. Didn't check the screen that way but it sure was a quick fix.
« Last Edit: May 19, 2011, 06:15:06 AM by Quicksilver » Logged
1997  Standard
csj
« Reply #5 on: May 19, 2011, 06:33:43 AM »
Could you please give me the part # from the bag.
Gotta order that part right away from my local dealer.
« Reply #6 on: May 19, 2011, 06:39:05 AM »
Any comments?
I admire your ability to take a close up picture! That's one trashed diaphragm...
SCREEN SET          16952-MZ0-003              $12.43
COVER SET,rooster    16953-MBZ-B51              $28.91
« Reply #7 on: May 19, 2011, 07:33:07 AM »
from a previous post of mine. the K&L is lower ocst than OEM. search is your friend
at the time valkyrie OEM was not avail.
"K&L Supply is the company name. Their website is very limited, however their customer # is very helpful.
#18-5254 (actual K&L part # for CBR1000F and other bikes, diaphragms and spring are the same, I just received this kit, it has extra o-rings not needed for our bike.) (Tucker Rockey # TR29-2506) more $$$ but all that is avail right now
http://www.cyclepages.com/ProductGroupDisp.aspx?ProductGroupID=4001277
For Valkyrie
TR29-2725 (actual tucker rockey part #)  (K&L 18-5018 is the K&L #)  cheaper $$ but not avail right now. It is listed on www.directlineparts.com
http://www.powersportsuperstore.com/K-L-SUPPLY-CO-PETCOCK-REPAIR-KIT-MULTIPLE-APPS-SEE-p/tr29-2725.htm "
« Last Edit: May 19, 2011, 12:09:25 PM by CA ExhaustCoatings » Logged
Quicksilver
« Reply #8 on: May 19, 2011, 12:07:50 PM »
cover set, rooster HM-16953-MBZ-B51- From dealer $42.58 plus tax
These were the parts included.
« Last Edit: May 19, 2011, 01:54:29 PM by Quicksilver » Logged
1997  Standard
Daniel Meyer
The State of confusion.
« Reply #9 on: May 19, 2011, 01:08:59 PM »
Does it come with the cover/vacuum port?
CUAgain,
Daniel Meyer
Bone
« Reply #10 on: May 19, 2011, 02:36:01 PM »
I bought the same kit for $36.41 in 4/10 from Direct Line. Mine didn't have a Sharpie Fine Point  Smiley Kit still in the bag I converted the petcock to manual.
