March 23, 2026, 06:51:20 PM *
Author Topic: Exhaust gaskets...Again  (Read 1070 times)
YoungPUP
Valparaiso, In
« on: May 18, 2011, 06:41:51 PM »
i'm switching exhaust. And for some reason or another I can't get the exhaust gaskets out. I've broken 3 dental picks, and don't want to get any more aggressive for fear of scarring the gasket surface. Now What? Sad
99 STD (Under construction)
Highbinder
Bastian/Tazewell,VA.
« Reply #1 on: May 18, 2011, 07:10:58 PM »
Go to Sears or one of the auto parts stores and pick-up a set of good picks, use the hooked one to get under the gasket and pull, I wouldn't be worried about scratching the surface, it takes a pretty deep scratch to hurt anything....sometimes when I don't have new gaskets I will just turn them over and put them back in and I have never had one leak yet....
« Reply #2 on: May 18, 2011, 07:51:49 PM »
I got tired of the same battle so picked up a small flat blade screwdriver, heated it a bit and bent a bit of a curve in the end. Took 2-3 tries to get it bent to the right angle, but I can now just stick the end in there, pry up a little and the gaskets pop right out. I filed the end down even sharper than it was, found it works better for me than a pick.
My big problem now....I can't find the fool thing, so guess I'll have to make another if ever needed.  tickedoff
Sonny
Holt, Mo.
« Reply #3 on: May 19, 2011, 06:52:00 PM »
I had the same problem when I put the stock exaust system back on.  Bent a small screw driver to pull them down and out.  I've had the exaust off sevral times since doing various work.  Never have replaced the gaskets and still no leaks..
What a great day, lets ride!
1999 Valkyrie Standard
2003 VTX, 1800C
