August 27, 2025, 06:26:54 AM *
Author Topic: Goldwing front brake rotors  (Read 4543 times)
Dan in AZ
« on: April 17, 2009, 11:27:28 AM »
Some of you have used the 1800 Goldwing front brake rotors on the Valkyrie. What year will fit the Valkyrie? I ordered the rotors for a 03 VTX 1800, was told they would fit, but they will not bolt onto the wheel. I just can't afford almost $600 for the Valkyrie replacement. Also if you have used the EBC rotors do you have a part number. Thanks in advance.   Dan
SCain
Rio Rancho, NM
« Reply #1 on: April 17, 2009, 03:01:10 PM »
Here is a link to the GL1800 part #'s, I believe all years are the same.
http://www.jkozloski.com/generic_parts.htm
Steve
Stude
« Reply #2 on: January 18, 2010, 10:35:49 AM »
Are you talking about the 1800 GoldWing rotors fitting a
Valkyrie Rune or a Valkyrie Interstate
X Ring
VRCC #27389, VRCCDS #204
« Reply #3 on: January 18, 2010, 12:46:49 PM »
1800 GW front rotors are supposed to fit all Valkyrie Standards, Tourers and Interstates.  You'd probably have to ask on a Rune board about whether they fit them also.
Marty
Mr.BubblesVRCCDS0008
« Reply #4 on: January 19, 2010, 04:42:31 PM »
I put the 1800 wing rotors on my 2000 interstate about two months ago. No problem at all and a lot cheaper than the valk replacement rotors. I got mine from HDL.
« Reply #5 on: January 19, 2010, 04:54:07 PM »
Bubbles, will those same rotors fit the 1999 InterState?
Hay  Cool
X Ring
« Reply #6 on: January 19, 2010, 05:24:27 PM »
All the Valk front rotors are the same and interchangeable.
Marty
« Reply #7 on: January 19, 2010, 09:45:50 PM »
I'm sure they would as Marty said all the front wheels are the same from 98 up. I think the 97s run different bearings not sure on the rotors for those.
X Ring
« Reply #8 on: January 19, 2010, 10:10:14 PM »
Rotors are the same.  Bearings are smaller but do not have a higher failure rate than the '98-'03s.
Marty
quexpress
Montreal, Québec, Canada
« Reply #9 on: January 20, 2010, 05:03:12 PM »
What prevents it from being bolted onto the wheel Dan?
I'm puzzled because EBC lists the same rotors for this VTX as for our Valks.
A few years ago, I have used that list to purchase different rotors for my Valk. The ones that I am presently using are either from a VFR800 or a CBR600 (not sure LOL). They are similar to this one.
Good luck with your swap!  cooldude
I still have a full deck.
I just shuffle slower ...
paulclark911
« Reply #10 on: May 30, 2015, 12:01:14 PM »
I see these post are a few years old, just wondering if you can in fact put the front rotors from a 1800 Wing on a 1999 Valkyrie and if you can what year will fit a 99 Valk.  Just had mine inspected and he said they are a bit thin and need to be replaced next time I replace the pad. Thanks for any information you can send my way.
Daniel Meyer
The State of confusion.
« Reply #11 on: May 30, 2015, 01:24:34 PM »
Yes, you can put 1800 Gold Wing front rotors on the front of a 1500 Valk...
Some of us did that because they were MUCH cheaper at the time.
Now, the Valk rotors are reasonably priced...so if you're buying new, go with the OEM Valk rotors.
CUAgain,
Daniel Meyer
paulclark911
« Reply #12 on: May 30, 2015, 04:11:15 PM »
I'm finding the OEM Valk rotors for about $150.00 each, but the 1800 Wing rotors are 1/2 that. Can you send me a link for OEM rotors?
mello dude
Dayton Ohio
« Reply #13 on: May 31, 2015, 01:43:01 PM »
Hi - I have a 1999 set for sale with 19k miles on them, very good condition, $200 shipping included. PM please......
lljjmm
« Reply #14 on: May 31, 2015, 04:35:03 PM »
Don't you also have to factor in if it is on a "J1" wheel or a "J2" wheel  on your bike?   Just to add confusion to the topic of rotors, calipers and wheels.
« Reply #15 on: May 31, 2015, 05:20:21 PM »
Aren't those the rear rims only? All fronts except as stated for the 97' are the same.
Daniel Meyer
« Reply #16 on: June 01, 2015, 11:19:15 AM »
That's a pretty good price for OEM at least as far as I can tell...
direct line says OEM goldwing rotors are about $266/ea and Valk rotors are are about $192...valk rotors USED to be over $300/ea...
http://www.hondadirectline.com/
CUAgain,
Daniel Meyer
indybobm
Franklin, Indiana VRCC # 5258
« Reply #17 on: June 01, 2015, 12:40:43 PM »
For the front wheels, 1997 rims are a 1J. 1998 and up are 2Js
So many roads, so little time
VRCC # 5258
Daniel Meyer
« Reply #18 on: June 01, 2015, 12:57:12 PM »
The bearing is the difference here, I believe. The rotors are the same.
CUAgain,
Daniel Meyer
paulclark911
« Reply #19 on: June 01, 2015, 06:44:19 PM »
Found these OEM Calipers $158.00 each
http://www.procaliber.com/oemparts/a/hon/506c2f6ff870023420a31b54/front-wheel
paulclark911
« Reply #20 on: June 01, 2015, 06:56:11 PM »
OEM Rotors $158.00
paulclark911
« Reply #21 on: June 01, 2015, 06:57:18 PM »
I meant to say Rotors not calipers
