February 02, 2026, 11:52:15 AM *
Author Topic: Sparkplugs - need a diagnosis and prescription  (Read 1728 times)
JerryH
« on: May 23, 2011, 11:48:44 AM »
Sorry no pics available.
1997, standard, 45000 miles, last plug change at 40,000 miles (plugs looked the same then as they do now).  MPG - around 33, Jardin pipes (had Cobra 6 packs on it till I bought it).  Was told the mechanic installed the Cobra "Jet" kit when the 6 packs were put on and shimed needle to #4.
Plugs #1, 2, 3 - look OK, nice clean tan color.
Plugs #4, 5, 6 - look terrible, black and sooty.???
Bike has recently started to "pop" on deceleration???
Installed a Pingel fuel valve a  month ago and plugged the Vacuum line going to #6 carb.
checked the clamps on the intake "tubes" all were loose - tightned all back down.
what does anyone suggest for a fix?
If anyone mentions "get into the carbs" for that shim.  Does anyone have a step by step to do that.  I do all the maintenance on the valk and pervious Wing, but carbs are not my strong suit. Cry  However, I am willing to try.
Jerry
Cliff
Manchester, NH
« Reply #1 on: May 23, 2011, 12:42:59 PM »
If I understand correctly the good ones are the front two ones on the right side (as sitting on the bike) and the front one (2) on the left side?
VRCC # 29680
JerryH
« Reply #2 on: May 23, 2011, 01:26:05 PM »
You've got it right Cliff.
Jerry
« Reply #3 on: May 23, 2011, 05:31:53 PM »
The needles being "Shimmed" to the #4 position is too rich. That may be the reason you only get 33 MPG. After starting on position #3 I dropped them to #2 down from the top and opened up the pilot screws to 2 1/4 turns out from lightly seated. Now I get 36-37 and it runs great. I need a bit of enrichment on cold mornings which is normal. I have Thunder Valley headers with custom made silencers.
JerryH
« Reply #4 on: May 24, 2011, 05:07:07 AM »
thanks Sandy - that sounds like my next plan.  Now - anybody have a step by step (maybe pictures) of getting inside and adjusting the shim??
Jerry
