February 02, 2026, 01:30:41 PM *
Author Topic: Differential leak, what did I do wrong  (Read 2450 times)
hmt81
« on: May 24, 2011, 02:18:51 PM »
First, thanks for all your posts as this was the first time I had the rear apart. This forum and wealth of information is just amazing. Had trouble getting the wheel off till I checked hear and saw I needed to wiggle the wheel & remove the wheel & drive together. I did try to pry a few times but finally wiggled off. I replaced all 3 o-rings, splines were in great shape, removed driveshaft & pumpkin, lubed u-joint end with Moly and pinion end of driveshaft with Belray water proof grease. Cleaned splines and coated with Moly. Put it all together & rode a few miles on the new tires. Got home and saw diff oil spray and it is leaking diff oil out the bottom cutout in the plastic ring. Do I need to replace some type of seal? When it was apart, all looked fine? Bike only has 12,800 miles..... Suggestions?
Henry
Daniel Meyer
The State of confusion.
« Reply #1 on: May 24, 2011, 02:47:23 PM »
Certainly sounds like the big seal...but it's really unusual to tear that up changing a wheel...
Are you certain you got the pinion seal into the pinion cup (on the driveshaft), it can leak oil and run/leak out the bottom of the swingarm/rear end point, and then run down to the bottom of the rear end...
CUAgain,
Daniel Meyer
« Reply #2 on: May 24, 2011, 02:56:24 PM »
Did you change the oil in the final drive?  How much did you put in it.  It takes 150cc is all
valkyriemc
NE Florida
« Reply #3 on: May 24, 2011, 03:06:36 PM »
Or filled with the bike standing straight up if your doing it by the "fill to the bottom of the fill plug hole" method.
Veteran USN '70-'76
hmt81
« Reply #4 on: May 24, 2011, 03:11:18 PM »
Thanks guys, first, I did not touch the diff fluid as that service was about 500 miles ago, never had any leaks. I did put Belray w/p grease in the pinion cup and on the pinion end of the driveshaft and it was inserted into the cup before I slid the assembly back into the swingarm.  The seal was into the cup. I did have to turn the pumpkin with the drive so I could engage the ujoint. I left the pinion nuts last, installed the orings, all 3 and torqued the axle, caliper, then did the 4 pumpkin nuts. I just rode it again for 5 miles, I park on the stand and it is just dripping out the weep hole?
Daniel Meyer
« Reply #5 on: May 24, 2011, 03:17:04 PM »
Sounds like the seal then...
CUAgain,
Daniel Meyer
hmt81
« Reply #6 on: May 24, 2011, 04:22:19 PM »
Just tore it back apart, looks like I must have hit the diff seal with the screwdriver when I was trying to pry the drive loose. My bad. Anyone have a clue to replacing this seal. looks like I have to pull the diff apart? Any help, I am mechanicly inclined but never done this before. Special tools?
« Reply #7 on: May 24, 2011, 04:35:26 PM »
Just the seal!
Use a couple of sheet metal screws to pull out the old seal and replace it with a new seal.
Pretty simple actually!
hmt81
« Reply #8 on: May 24, 2011, 04:53:33 PM »
can it really be that simple, just screw in some small screws just a tad and then pull on them to remove the seal. I guess I could drive the new one in using  a small can maybe?
hmt81
« Reply #9 on: May 24, 2011, 06:54:30 PM »
Thanks, screw worked, seal out, new one on it's way!
F6Dave
« Reply #10 on: May 24, 2011, 07:51:33 PM »
A dealer actually told me I'd have to tear the final drive apart to replace the big seal.  Good thing I didn't believe him!  Removal is easy -- I just used a screwdriver to pop the old one out.  I thought I'd need a fancy tool to drive the new one in, but I just lubed it and gently seated it with my thumbs.  A very simple job!
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #11 on: May 24, 2011, 08:37:48 PM »
hmt81......is the seal you are replacing honda # 91265-MY3-003?
hmt81
« Reply #12 on: May 25, 2011, 01:55:31 PM »
Yes, that's the p/n I came up with in the fiche.
hmt81
« Reply #13 on: May 27, 2011, 02:06:58 PM »
Thanks to all for the suggestions & remedy. It was the pinion seal & the screw to remove the seal worked great. Also followed the suggestion to lube & press in by hand. So far all is well. Learned my lesson.
