February 02, 2026, 11:52:18 AM *
Author Topic: Necessary to replace these?  (Read 1614 times)
JetDriver
Columbus, OH
« on: May 24, 2011, 03:33:44 PM »
I've got the rear wheel off and have decided to check the drive shaft and pinion cup.  I look at the manual and now see that the "stopper ring" (is that the pinion seal?) on the pinion end of the shaft should be replaced with a new one.  Is that necessary?  Also,  the damper holder plate bolts are supposed to be replaced with new.  Does everybody do that?
Daniel Meyer
The State of confusion.
« Reply #1 on: May 24, 2011, 03:40:32 PM »
I don't replace the "stopper ring" unless it's torn up, and I don't replace the bolts in the wheel either...just add a little anti-seize or loctight (corrosion is the issue in my opinion).
CUAgain,
Daniel Meyer
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #2 on: May 24, 2011, 05:25:44 PM »
#1 on daniel meyer....ifyou replaced everything that the manual says to replace when you service something on the bike, before it was all said and done, then you would have a practically new ride.  reuse those parts unless they appear broken or screwed up.
