February 02, 2026, 01:30:45 PM *
Author Topic: Helmet holder cable part number  (Read 2161 times)
csharg
CA
« on: May 26, 2011, 07:36:40 AM »
I just picked up a low milage '01 standard, and it was missing a few things such as the battery box cover, strap, and helmet holder cable.  I have looked through the microfiche, and I am wondering if I have the right part number for the helmet strap.
The one I found was #6 on the SEAT page (WIRE, HELMET SET  77236-KAZ-780).  Is this the right number?
Also, is there a good place to pick up some progressive springs and timing belts?
Thanks.
custom1
01 Interstate
SW Pa
« Reply #1 on: May 26, 2011, 08:22:53 AM »
Can't help much on the other parts, but here is a link to the timing belt numbers. You can get them cheaper locally than from Honda.
http://www.jkozloski.com/generic_parts.htm
John
« Reply #2 on: May 26, 2011, 09:18:20 AM »
I've never seen anyone use the OEM helmet holder cable. BigBikeParts makes a clutch pin replacement that is a great helmet lock. I've used mine for years.
Bob E.
Canonsburg, PA
« Reply #3 on: May 26, 2011, 10:43:47 AM »
I use it occasionally.  Wink
donaldcc
Palm Desert, CA
« Reply #4 on: May 26, 2011, 11:23:19 AM »
  A friend of mine is using this and is sending me an extra he has at home.  Clips it to mirror support.
Much more convenient than the OEM that I never use.  Also come with a 70" cable ($10) you can use to secure a jacket, etc.
« Last Edit: May 26, 2011, 11:24:56 AM by donaldcc » Logged
Don
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #5 on: May 26, 2011, 11:48:21 AM »
csharg....yep....that's the right number.....but i'll guarantee you this:  9 out of 10 of these valkyrie riders do not use the cable.  in fact...if you looked under the seat of most of these bikes the cable is not there-it's at their garage hanging on the wall.
JC
The Beast
Franklin, TN
« Reply #6 on: May 26, 2011, 12:01:03 PM »
The stock helmet cable is crap, don't waste your time. I'm using the Kewl Metal locks on the end of my Kyurakyn grips and I like them http://www.cruisercustomizing.com/detail.cfm?model_id=0&Category_ID=9&manufacturer_ID=278&product_ID=13150&sblid_name=Kewl_Metal_Chrome_CNC_Billet_Helmet_Lock
csharg
CA
« Reply #7 on: May 26, 2011, 02:01:07 PM »
Thanks for the tips. Those do seem a lot more convenient..
valkyriemc
NE Florida
« Reply #8 on: May 26, 2011, 02:43:38 PM »
Do you know if that rear end has been serviced at all?
http://www.valkyrieriders.com/shoptalk/Elusive%203rd%20O-Ring.htm
Veteran USN '70-'76
NITRO
Eau Claire, WI
« Reply #9 on: May 26, 2011, 05:44:31 PM »
I have a couple of the cables you can have free if you insist on having one. With the IS now I have zero use for them.
When in doubt, ride.
Brad
Reno, Nevada
« Reply #10 on: May 26, 2011, 09:42:45 PM »
I use a gun cable lock and secure it to the sissy bar and let the helmet sit on the passenger seat.
fordmano
San Jose, CA.
« Reply #11 on: May 27, 2011, 12:43:55 AM »
I was curious,, so I had to go look since I have never seen or heard of such a part that came stock on a Valkyrie... DUH! maybe because I have an Intersate with dual helmet locks at the rear under the trunk...
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
Kymbo
South Australia
« Reply #12 on: May 27, 2011, 01:22:01 AM »
 +1  cooldude
