February 02, 2026, 11:52:15 AM *
Author Topic: Question about banjo bolt washers  (Read 2682 times)
Bugslayer
Lubbock, Texas
« on: May 26, 2011, 10:27:41 AM »
Can I reuse the banjo bolt washers on the rear master cylinder?  Are these rubber or brass washers?
« Reply #1 on: May 26, 2011, 10:59:34 AM »
The first time I rebuilt my calipers, my rear one leaked at the banjo bolt. Turns out I was
too timid to tighten that hollow bolt as much as it needed to be tightened. I saw that it was
leaking (just barely leaking) before I rode off, so there was no bad.
The washer in question is a "crush" washer, and it does crush some when used. There's an
assortment pack of copper crush washers at Advance Auto, and there's a couple in there
that are just the right size for Valkyrie banjo bolts, I'm sure you can get the right size a
bunch of other places..
If you use the 3/8ths inch ratchet handle instead of the wimply 1/4 incher, you can
probably get away with reusing the original crush washer any number of times...  Wink
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #2 on: May 26, 2011, 11:40:28 AM »
bugslayer....you can reuse the washers on the rear banjo bolts...just put them back on the same way (direction) that you took them off...also, make sure you tighten them...if i remember right the torque is:  25 foot pounds.  you will not have a problem with them leaking.  good luck.
Bugslayer
Lubbock, Texas
« Reply #3 on: May 26, 2011, 12:57:05 PM »
Cool! Thats good to know about the washers at Advance Auto. If my old washers leak, I'll see if I can find the ones you mentioned.
I'm waiting for some parts to be delivered, so I can't do anything until they get here.  I just don't want my parts to come in, and then have to order two washers.
Thanks for the help!
Bugslayer
Lubbock, Texas
« Reply #4 on: May 26, 2011, 12:57:59 PM »
Good deal..... Thanks!
